AUDIOPHONICS GXDC-25 Power Cable Jack DC 5.5/2.5mm to GX16 OFC Copper for LHY Power Supplies 1m
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.5mm connector and a GX16 connector. It can only be used with LHY power supplies, replacing the original cables. This cable is indeed designed with a Sommercable Meridian SP215 cable made of OFC copper conductors with a section of 1.5mm², ensuring an excellent electrical conductivity. It is terminated with Viborg DC25G and GX16G connectors with gold-plated copper alloy contacts, maintaining a very good level of conductivity.
Reference : 19551
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 16-04-2025.
This cable IS NOT compatible with the following power supply references: 8718/14183/9646/8817/9575/9645/13387/11501/9644
Audiophonics Power Cable GXDC-25
AUDIOPHONICS POWER CABLE GXDC-21 : Front view
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.5mm connector and a GX16 connector. This cable is designed with a Sommercable Meridian SP215 cable made of OFC copper conductors with a section of 1.5mm², ensuring an excellent electrical conductivity. It is terminated with Viborg DC25G and GX16G connectors with gold-plated copper alloy contacts, maintaining a very good level of conductivity while ensuring a high resistance to oxidation. The cable is finally covered with a beautiful black and grey braided sheath from Viablue.
This cable is only compatible with LHY power supplies.
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain devices. Using a non-compatible cable can result in the destruction of your equipment.
AUDIOPHONICS POWER CABLE GXDC-21 : Pin 1 and 2
Product typePower cable
Length1m
Connectors1x GX16
1x Jack DC 5.5/2.5mm
Cable conductors materialOFC Copper
Cable conductors section2x1.5mm²
Cable diameterØ8mm
Connectors contacts platingGold
Cable colorBlack and grey
Connectors colorGrey
Length (m)1.0
ShieldingNC
Section (mm²)1.5
ConnectorGX16
ConnectorJack DC
Câble secteur DC
Apporte un vrai plus , plus d’ouverture , scène plus ample , pas d’agressivité ni effondrement de la dynamique, un petit rodage et que du bonheur
This review has been posted for AUDIOPHONICS GXDC-25 Power Cable Jack DC 5.5/2.5mm to GX16 OFC Copper for LHY Power Supplies 1m
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.5mm connector and a GX16 connector. It...
