AUDIOPHONICS Power Cable Jack DC 5.5/2.5mm to GX16 OFC Copper for Audiophonics LPSU100 Power Supplies 1m
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.5mm connector and a GX16 connector. It can only be used with our Audiophonics LPSU100 power supplies, replacing the original cables. This cable is indeed designed with a Sommercable Meridian SP215 cable made of OFC copper conductors with a section of 1.5mm², ensuring an excellent electrical conductivity.
Reference : 17398
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 16-04-2025.
This cable is ONLY COMPATIBLE with the following power supply references: 8718 / 14183 / 9646 / 8817 / 9575 / 9645 / 13387 / 11501 / 9644
Audiophonics Power cable
Jack DC 5.5/2.5mm to GX16 OFC Copper with Audiophonics LPSU100 Power Supplies 1m
Audiophonics Câble d'alimentation Jack DC 5.5/2.5mm vers GX16 Cuivre OFC 1m
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.5mm connector and a GX16 connector. It can only be used with our Audiophonics LPSU100 power supplies, replacing the original cables. This cable is indeed designed with a Sommercable Meridian SP215 cable made of OFC copper conductors with a section of 1.5mm², ensuring an excellent electrical conductivity. It is terminated with Viborg DC25G and GX16G connectors with gold-plated copper alloy contacts, maintaining a very good level of conductivity while ensuring a high resistance to oxidation. The cable is finally covered with a beautiful yellow and grey braided sheath from Viablue.
This cable is only compatible with Audiophonics LPSU100 power supplies.
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain devices. Using a non-compatible cable can result in the destruction of your equipment.
AUDIOPHONICS Câble d'Alimentation Jack DC 5.5/2.5mm vers GX16 Cuivre OFC 1m
Product typePower cable
Length1m
Connectors1* GX16
1* Jack DC 5.5/2.5mm
Cable conductors materialOFC Copper
Cable conductors section2*1.5mm²
Cable diameterØ8mm
Connectors contacts platingGold
Cable colorGray and yellow
Connectors colorGray
Length (m)1.0
ShieldingNC
Section (mm²)1.5
ConnectorJack DC
ConnectorGX16
5 reviews
Avis
Câble très bien conçu,et très qualitatif.
This review has been posted for AUDIOPHONICS Power Cable Jack DC 5.5/2.5mm to GX16 OFC Copper for Audiophonics LPSU100 Power Supplies 1m
Avis
sur une alimentation dac marche très bien
c'est un cable que j'ai monté moi mème manque la viborg je rajouterais après l'autre prise a tout l'air d'etre une electerco
ca cable ouvre le son les mediums et les timbres sont manifiques, bref il est musical
un très bon prix que fait audiophonics vu le prix ders connecteurs, le cable lui meme coute 5€ mais il assure avec une bonne tresse de connection que j'ai connecté coté source
NUC Intel cable 2.5 mm.
Great Value for the money.
The new Power cable take you a step up at the sound ladder.
Thanks Audiophonics again :-)
The new cable take you a step up at the sound ladder.
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.5mm connector and a GX16 connector. It...
