This Cable not works with my linearPowersupply 12 V 5A
This affordable, high-quality power cable features a 2-pin GX16 female connector (also known as an aviation connector) and a DC 5.5/2.5mm and 5.5/2.1mm jack connector. This cable ensures excellent electrical signal conductivity for powering your devices or modules. A red and black nylon sheath protects the cable. This sheath ensures good flexibility and resistance to mechanical stress.
Positive pole: GX16: Pin 2 -> Pin Central on DC jack
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain products. Using a non-compatible cable could destroy your equipment.
This cable is not compatible with the following Audiophonics linear power supplies (different polarity) :
AUDIOPHONICS Double Regulated Linear Power Supply 5V / 12V 30W T-Amp V-DAC2 LT1085
AUDIOPHONICS Double Regulated Linear Power Supply USB 2x 5V 1.5A 7.5W LT1086
Product type | Power câble |
Connectors | GX16 female 2-pole DC 5.5/2.5mm and 5.5/2.1mm jack |
Conductors material | Copper alloy |
Sheath | Nylon |
Cable length | 1m |
Color | Black and red |
Weight | 48g |
Package | 1x Power cable GX16 to DC jack 5.5/2.5mm and 5.5/2.1mm |
Length (m) | 1.0 |
Shielding | NC |
Section (mm²) | N/A |
Connector | GX16 |
Connector | Jack DC |
Conductors material (Cable) | Copper Alloy |
Conductors Plating (Cable) | None |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
