Max sampling rate
DAC / ADC Chip
Amplifier chip
Class
Power (W)
45 - 165
Input voltage (V)
V
V
Output voltage (V)
Channel
Input
Output
Remote Control
Networking
Transmission / Reception protocol
Streaming services
Color
Igor C.
the bananas fit perfectly into the rca connectors, the only complaint is that they are long, so they cannot be pushed all the way
olivier r.
Très bon mais pas neutre
bande passante très équilibrée, léger voile dans les aigus provenant d'une petite coloration, légère mais néanmoins...
FRANK D.
Produit mysterieux... Mais tant efficace.
Des fois il suffit juste d'essayer et voila que je confirme que ca fonctionne a merveille.
Faut juste ne pas en mettre de...
Desktop headphone amplifiers
Want to enjoy optimal headphone listening at home? Our range of sedentary headphone amplifiers is made for you. A wide selection of headphone amplifiers for both sensitive headphones and high-impedance models.
