This new headphone amplifier is based on the design of its big brother of the series "Master" flagship of the mark.
This one because of its extensive connectivity, particularly surprising for a product of this range is compatible with all the analog sources and amplifiers of power of the market.
Its volume management is based on a high-precision digital control with relay of the faults inherent to the potentiometers.
NFB is the acronym for Non-feedback, a technology used by Audio-Gd so that it does not "color" the sound at the level of the output stage electronics, giving you a sound of professional neutrality.
The 100% discreet design of this amplifier is backed by a high power class A power supply.
The 24k Gold Plated RCAs and the Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Signal / noise ratio |
Gain | 0DB on Low gain, + 9DB on High gain |
Output Level |
Preamplifier output power |
Output Power (Headphones) . |
Output Impedance | 1 ohm @ XLR |
Frequency Response | 20Hz - 20KHz (<0.15DB) |
Consumption | 21W |
Dimensions | 240mm X 360mm X 80mm |
Weight | 5KG |
Accessories | Power cord |
[Img-11825-left-thickbox_default]
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
