Audio-GD REFERENCE 10.32 DAC 24bit / 192kHz USB / Coax / Optical Amanero
Reference : 6529
2 159,00 €tax incl.
1 799,17 € tax excl.
Including 1,00 € for green tax
The latest 10.32 reference in the family of Audio-GD family integrates the new USB interface of the brand (Amanero).
This new product also offers Upsampling up to 8X thanks to its built-in DSP1, its volume controller based on 4-channel digital relays is an example of transparency.
This unit combines the functions of preamplifier DAC and headphone amplifier is delivered with its dedicated remote control.
Son Modern DAC allows you to manage 24bit 192Khz sources directly via USB and 24bit 96kHz via SPDIF.
The 100% discrete design of this preamplifier is backed by a group of 8 dedicated Class A power supplies.
24k Gold Plated RCAs and Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Signal / noise ratio
120db
Gain
+7 DB (volume control at 70 steps) (XLR)
+ 13DB (99-step volume control) (XLR)
USB Interface
VT1731 (USB32)
converters
4 X PCM1704UK
Headphone output power capacity
6000MW / 50 ohms 3500MW / 100 ohms 1200MW / 300 ohm 600MW / 600 ohms
Volume characteristics
Linéaire @ 70 not
Exponential @ 99 not
Output impedance
1 ohm / Headphone output
1 ohm / DAC output
Output Levels
Headphone Output: 19V RMS
Output variable preampli output: 10V RMS
Variable Output DAC: 5 V RMS
ACSS: 1.2MA + 1.2MA
Input sensitivity
0.5 Vp-p (75 Ohms, Coaxial)
19 dBm (Optical)
USB1.1, USB2.0 (Full Speed)
Frequency Response
20Hz -20KHz (<- 0.1DB)
1Hz - 140KHz (- 3DB)
Dimensions430 x 430 x 93 mm
Weight
15KG
Accessories
AC power cord X1
USB cable X1
</ P>
</ P>
Manufacturer:
</ P>
https://www.audiophonics.fr/images2/6529/6529_AUDIOGDREFERENCE10.2_1.jpg
</ P>
</ P>
https://www.audiophonics.fr/images2/6529/6529_AUDIOGDREFERENCE10.2_2.jpg
https://www.audiophonics.fr/images2/6529/6529_AUDIOGDREFERENCE10.2_3.jpg
https://www.audiophonics.fr/images2/6529/6529_AUDIOGDREFERENCE10.2_4.jpg
https://www.audiophonics.fr/images2/6529/6529_AUDIOGDREFERENCE10.2_5.jpg
InputBNC
InputXLR
OutputACSS
