Aune T1 MK2 Headphone Amplifier/DAC USB 24bit/96khz RCA Silver
Reference : 9876
179,00 €tax incl.
149,17 € tax excl.
This small hybrid headphone amplifier with superb design comes back with a new Asynchronous USB interface.
Its USB input also acts as an analog digital converter 24bit / 96khz.
Pulling out of the best of both worlds this low priced amplifier features the transistors dynamics associated with the heat of the Electro-Harmonix tube 6922EH.
The DAC part is equipped with a Burr-Brown PCM1793 and its USB interface Saviaudio SA9027 supports the 24bit / 96khz asynchronous.
This device is particularly good at reviving digital recordings that lack heat.
Characteristics :
  • Can be used as preamplifier via USB only
  • Audiophiles components: Alps potentiometer, Wima and Elna capacitors, precision resistors ...
  • Tube: 6922 compatible EH (6DJ8 / ECC88 / 6922 / E88CC / ​​6N23P / 6N23P-EB)
  • Color: Silver
  • Aluminum Case
  • Weight: 1.5 kg
  • Size: 155mm x 97x 40mm
  • Gain adjustable by DIP switch: 0, 10 or 16db
  • Frequency response: 20hz-20khz
  • Signal Noise Ratio:> = 120db
  • Line Output: 2Vrms
  • Supported Headphone Impedance: 30ohm ~ 600ohm
  • Headphone Output Power: 32ohm - 1000MW, 120ohm - 400MW, 300ohm - 150MW
  • Supported sampling rates: 24bit / 96kHz
  • Inputs: Analog stereo RCA, USB
  • Outputs: Analog stereo RCA, 6.35 mm jack
  • Supplied with power and USB cable
  • IPad compatible with the Apple Camera / USB and a powered HUB
[Img-10845-left-thickbox_default]
[Img-10846-left-thickbox_default]
[Img-10847-left-thickbox_default]
[Img-10848-left-thickbox_default]
[Img-10849-left-thickbox_default]
[Img-10850-left-thickbox_default]
[Img-10851-left-thickbox_default]
[Img-10852-left-thickbox_default]
https://www.audiophonics.fr/images2/6793/6793_AUNET124BITUSBDAC_7.jpg
https://www.audiophonics.fr/images2/6793/6793_AUNET124BITUSBDAC_8.jpg
Bluffé!
Ce petit DAC trône fierement aux côtés de mon Yaqin 5881B tubé NOS, il convertit honorablement ma musique via Daphile. Excellente qualité sonore, améliorée encore avec un tube JAN Philips ECG NOS 6922. A ce prix il fait des merveilles.
This review has been posted for Aune T1 MK2 Headphone Amplifier/DAC USB 24bit/96khz RCA Silver
