AUNE X7S 2021 EDITION Headphone Class A amplifier Variable Out Balanced Out Silver
The pure class A Aune X7S balanced output headphone amplifier is the result of a long research after the nomadic headphone amplifier Aune B1 and the Aune Panda. It is the natural companion of the DAC Aune X1S 32bit 384Khz DSD SABRE ES9018K2M. This headphone amp, completely in class A, is the synthesis of all the know-how of Aune Audio.
By buying this product you get 25 loyalty points
Reference : 15098
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 22-04-2025.
Aune X7S 2021 Edition
Aune X7S 2021 EditionAmplificateur Casque Class A Sortie Variable / Symétrique Argent
2021 Edition
The X7s, for this 2021 edition, sees its audio circuit slightly improved, including the arrival of a new transformer and more efficient capacitors. These modifications contribute to a better sound reproduction.
The pure class A Aune X7S balanced output headphone amplifier is the result of a long research after the nomadic headphone amplifier Aune B1 and the Aune Panda. It is the natural companion of the DAC Aune X1S 32bit 384Khz DSD SABRE ES9018K2M. This headphone amp, completely in class A, is the synthesis of all the know-how of Aune Audio. It is specially designed for high-end high-impact audiophile headphones such as: Sennheiser HD650, IE800, HD800, Beyerdynamic (Tesla) T1, DT880, AKG K701, K240.
Its gain-setting gain setting by "switch" allows a perfect adaptation of impregnation for both low and high impregnation headphones. Its structure is made up of 8 class A polarized transistors divided into 4 groups designed with a true symmetrical layout for cross talk and inaudible, backward background noise. The European sound of the Aune X7S developed by an English team has body, a deep sound image with increased natural musical tracking, a true sound signature of headphone amplifiers in class A. The separate 15 V separate low noise regulated power supply provides the stability necessary for the Aune X7S to operate properly in class A. By its unique design the Aune X7S will be an ideal companion for the digital player made of materialized Aune X5.
Review and measurements by Audio Science Review
The Audio Science Review forum offers a particularly complete test of the Aune X7s with in particular precise measurements of the different parameters of the device.
ClassA
Frequency response20Hz-200kHz @ -0.3dB
Noise level3µV
THD0.00013%
Inter-modulation distotion (CCIF protocol)RCA : 0.000036%
XLR 0.00057%
Output powerRCA : 250mW @ 300 Ohm / 1000mW @ 32 Ohm
XLR : 1000mW @ 300 Ohm / 1700mW @ 32 Ohm
SNRJack 6.35mm : 117dB
XLR : 125dB
Input1x Stereo RCA
Outputs1x Variable stereo RCA
1x Jack 6.35mm
1x XLR 4 polesbalanced
Dimensions145 x 171 x 45mm
Weight2kg
ColorSilver
Input
  • RCA
Output
  • Jack 6.35mm
  • RCA
  • XLR
Color
  • Silver
Class
  • Class A / AB
Remote Control
  • No
Amazing, smooth, detailed, dark background
I'm using Sennheiser HD6xx and Audeze LCD-1 headphones. I also have the B1S from Aune. The headphone amp sounds "liquidy". It's easy to place instruments in space. The background is very dark. I would not call class A warm, just pleasant / sweet sounding. Excellent for long listening sessions. For comparison, I have Hegel H95 and I tried Woo Audio WA7 3rd gen, and I prefer this amp.
This review has been posted for AUNE X7S 2021 EDITION Headphone Class A amplifier Variable Out Balanced Out Silver
The pure class A Aune X7S balanced output headphone amplifier is the result of a long research after the nomadic headphone amplifier Aune B1 and...
