By buying this product you get 239 loyalty points
With its Soloist 3GT DELUXE, Burson Audio offers a powerful and efficient headphone amplifier. It benefits from a dual mono balanced architecture, with independent circuits for each circuit. This design allows it to provide a good energy reserve while promoting a precise sound reproduction and a wide sound stage. Each channel has three discrete V6 Vivid OPAs per channel, which contributes to the sound transparency of the unit.
A large power supply circuit is used to provide a clean and stable electrical signal to all sections of the device at all times. This includes no less than five MCPS power supplies pushed to their maximum.
To all this, Burson Audio adds features to further improve the audio quality of the device. There are notably three levels of crossfeed emulation, managed directly at the hardware level in order to avoid generating distortion while optimizing the sound reproduction for headphone listening. The volume control is also optimized, using for each channel a MUSES72320 chip and a V6 Vivid discrete AOP in buffer, eliminating interferences between channels. It is also possible to adjust the volume level separately for each channel, to suit your listening space and its acoustics.
The Soloist 3GT DELUXE case functions as a large heat sink. Its high rigidity also allows the integrated fan not to create any resonance. In addition, the fan used is a Noctua model that is extremely quiet.
The Burson Audio Super Charger 5A power supply has an input voltage of 100-240VAC and an output voltage of 24VDC 5A. It also comes with adaptors for use with EU, UK, USA and AUS mains sockets. Furthermore, the Super Charger operates at a higher frequency than many mains adapters on the market, well above the threshold of human hearing, drastically reducing the level of continuous noise and therefore improving the signal-to-noise ratio. In particular, noise reduction allows many micro-details to be brought to the front.
The Burson Audio Cool Stand allows Burson Class A amplifiers to be placed vertically, saving space and improving heat dissipation. The stand consists of four machined aluminium feet with non-slip silicone pads on the inside to receive the amplifier.
Product type | Headphone amplifier |
Inputs | 2x Stereo RCA 1x Mic Bypass |
Outputs | 1x Stereo RCA 1x Subwoofer output 2x Single-ended Jack 6.35mm headphone output 1x Single-ended Jack 3.5mm headphone output |
Input impedance | 35kΩ |
Frequency response | 0Hz - 48kHz ±1dB |
Total harmonic distortion (THD) | < 0.0015% |
Output impedance | Headphone amplifier : 0.5Ω Pre-Out : 25Ω |
Power output | 10W @ 16Ω, SNR 112dB, Channel separation 99% 8W @ 32Ω, SNR 110dB, Channel separation 99% 3.8W @ 100Ω, SNR 111dB, Channel separation 99% 1.3W @ 150Ω, SNR 110dB, Channel separation 99% 640mW @ 300Ω, SNR 109dB, Channel separation 99.5% |
Dimensions | 255 x 270 x 70mm |
Weight | 5kg |
Housing material | Aluminum |
Package | 1x Burson Audio Soloist 3 GT 1x Remote control 1x Power supply 24V 5A 2x XLR to RCA adapters 4x Cool Stand |
Input | RCA |
Output | Jack 6.35mm |
Output | Jack 3.5mm |
Output | RCA |
Color | Silver |
Class | Class A / AB |
Remote Control | Yes |
