BURSON AUDIO SOLOIST 3XGT Headphone Amplifier Preamplifier Balanced Class A
With its Soloist 3X GT, Burson Audio offers a powerful and efficient headphone amplifier. It benefits from a dual mono balanced architecture, with independent circuits for each circuit. This design allows it to provide a good energy reserve while promoting a precise sound reproduction and a wide sound stage. Each channel has three discrete V6 Vivid PDUs per channel, which contributes to the sound transparency of the unit.
By buying this product you get 249 loyalty points
Reference : 16176
2 490,00 €tax incl.
2 075,00 € tax excl.
Burson Audio Soloist 3XGT
Burson Audio Soloist 3X GT Amplificateur Casque Préamplificateur Symétrique Class A
With its Soloist 3XGT, Burson Audio offers a powerful and efficient headphone amplifier. It benefits from a dual mono balanced architecture, with independent circuits for each circuit. This design allows it to provide a good energy reserve while promoting a precise sound reproduction and a wide sound stage. Each channel has three discrete V6 Vivid PDUs per channel, which contributes to the sound transparency of the unit.
A large power supply circuit is used to provide a clean and stable electrical signal to all sections of the device at all times. This includes no less than five MCPS power supplies pushed to their maximum.
To all this, Burson Audio adds features to further improve the audio quality of the device. There are notably three levels of crossfeed emulation, managed directly at the hardware level in order to avoid generating distortion while optimizing the sound reproduction for headphone listening. The volume control is also optimized, using for each channel a MUSES72320 chip and a V6 Vivid discrete AOP in buffer, eliminating interferences between channels. It is also possible to adjust the volume level separately for each channel, to suit your listening space and its acoustics.
The Soloist 3X GT case functions as a large heat sink. Its high rigidity also allows the integrated fan not to create any resonance. In addition, the fan used is a Noctua model that is extremely quiet.
xxx
Inputs2x Stereo XLR
2x Stereo RCA
1x Mic Bypass
Outputs1x Stereo XLR
1x Stereo RCA
1x Subwoofer output
1x Balanced 4 poles XLR headphone output
1x Single-ended Jack 6.35mm headphone output
1x Single-ended Jack 3.5mm headphone output
Input impedance35kΩ
Frequency response0Hz - 48kHz ±1dB
THD< 0.0015%
Output impedanceHeadphone amplifier : 0.5Ω
Pre-Out : 25Ω
Power (Balanced)10W @ 16Ω, SNR 112dB, Channel separation 99%
8W @ 32Ω, SNR 110dB, Channel separation 99%
3.8W @ 100Ω, SNR 111dB, Channel separation 99%
1.3W @ 150Ω, SNR 110dB, Channel separation 99%
640mW @ 300Ω, SNR 109dB, Channel separation 99.5%
Power (Single-ended)5W @ 16Ω, SNR 112dB, Channel separation 99%
4W @ 32Ω, SNR 110dB, Channel separation 99%
1.9W @ 100Ω, SNR 111dB, Channel separation 99%
650mW @ 150Ω, SNR 110dB, Channel separation 99%
320mW @ 300Ω, SNR 109dB, Channel separation 99.5%
Dimensions255 x 270 x 70mm
Weight5kg
Housing materialAluminum
Package1x Burson Audio Soloist 3X GT
1x Remote control
1x Power supply 24V 5A
1x Power cable
2x XLR to RCA adapters
InputXLR
OutputJack 3.5mm
OutputJack 6.35mm
ColorSilver
ClassClass A / AB
Remote ControlYes
With its Soloist 3X GT, Burson Audio offers a powerful and efficient headphone amplifier. It benefits from a dual mono balanced architecture, with...
