BURSON AUDIO SOLOIST 3X PERFORMANCE Headphone Amplifier Preamplifier Balanced Class A
A vastly improved version of the original Soloist, released in 2015, Burson Audio's Soloist 3X takes up the concept of the original Soloist, including fully discrete circuitry, a resistor-based volume control (ladder), and Class A amplification.
By buying this product you get 139 loyalty points
Reference : 14952
1 390,00 €tax incl.
1 158,33 € tax excl.
Burson Audio Soloist 3X Performance
Burson Audio Soloist 3X Performance Amplificateur Casque Préamplificateur Symétrique Class A
An astonishing power
The Soloist 3X is capable of developing a large power of 8000mW symmetrically or 4000mW asymmetrically. Thus, it is able to accompany demanding helmets as well as extremely sensitive models without any audible noise.
In order to achieve such a high power output, it includes 3 Maximum Current Power Supplies (MCPS) specially designed by Burson. These MCPS provide the Class A audio circuit with a large, clean and stable electrical signal.
Elitist volume control
The volume control of the Soloist 3X uses the legendary MUSES72320 chip, usually used in very high-end and much more expensive devices. This resistor ladder circuit provides perfect channel balance, ensuring an incredible sound stage. In addition, this volume control is coupled with a three-level gain control and an input buffer stage.
The shortest route is always the best
To reduce the length of the signal path when using an external DAC or preamplifier with volume control, Soloist 3X allows you to bypass the MUSES72320 volume control.
It is also possible to use Soloist 3X to boost the power of your favorite sound card while centralizing the volume control of your favorite playback software.
Finally, the Soloist 3X also adapts to your listening experience, integrating AOPs mounted on DIP8 and therefore easily interchangeable to modify the sound reproduction.
Product typeBalanced headphone amplifier
Preamplifier
Amplification typeClass A
Inputs1x Balanced XLR
1x Single-ended RCA
1x Mic bypass
Outputs1x XLR Preamp / DAC
1x Balanced headphone output XLR 4 poles
1x Single-ended headphone output Jack 6.35mm
1x Single-ended headphone output Jack 3.5mm
Input impedance35kΩ
Frequency response0Hz - 48kHz ±1dB
THD0.0015%
Output impedanceHeadphone output : 0.5Ω
Pre Out : 25Ω
Power output8W @ 16Ω, balanced, SNR 110dB, Separation 99%
4W @ 16Ω, single-ended, SNR 110dB, Separation 99%
4W @ 32Ω, balanced, SNR 110dB, Separation 99%
2W @ 32Ω, single-ended, SNR 110dB, Separation 99%
1W @ 100Ω, balanced, SNR 112dB, Separation 99%
0.5W @ 100Ω, single-ended, SNR 112dB, Separation 99%
600mW @ 150Ω, balanced, SNR 105dB, Separation 99%
300mW @ 150Ω, single-ended, SNR 105dB, Separation 99%
300mW @ 30Ω, balanced, SNR 106dB, Separation 99.5%
150mW @ 300Ω, single-ended, SNR 106dB, Separation 99.5%
Power supply24VDC (power supply included)
Dimensions200 x 250 x 60mm
Weight3kg
Housing materialAluminum
ColorSilver
Package1x Burson Audio Soloist 3X Performance
1x Remote control
1x Power supply
1x RCA Cable
Input
  • RCA
  • XLR
Output
  • Jack 3.5mm
  • Jack 6.35mm
  • XLR
Color
  • Silver
Class
  • Class A / AB
Remote Control
  • Yes
2 reviews
Un superbe Ampli casque
tout simplement le meilleur ampli casque a transistor que j'ai pu ecouter... une transparence juste incroyable, il vous revelera toutes vos sources avec justesse et précision.
la conception est entierement symetrique, les resultats deja exceptionnels avec une connexion "single-ended" sont encore ameliorés en passant a un cable symetrique .
il drive des planars tres gourmands tres facilement ( hifiman arya ) en high gain
parfaitement silencieux, son mode low gain permet meme d'utiliser des IEM tres sensibles sans aucun bruit de fond!
il peut egalement faire office de preampli dans un systeme hifi de salon, et aussi faire office d'ampli de puissance casque si vous avez déjà un preampli !
point d'attention : la telecommande fournie avec ne marchait pas a réception malgré plusieurs changement de piles.
Gros point positif au service client audiophonics : la telecommande a été remplacée en l'espace de qq jours !!!!
 (3)
This review has been posted for BURSON AUDIO SOLOIST 3X PERFORMANCE Headphone Amplifier Preamplifier Balanced Class A
Little Big Amp
Après quelques semaines d'utilisation maintenant, je dirais que le Soloist 3X est un ampli puissant, précis et énergique. Mais ni les basses ni les aigus ne sont exagérés.
La profondeur de la scène sonore, la clarté et l'impact sont tous des points forts du 3X.
C'est un très bon couple avec mon casque (Kennerton "Gjallarhorn) qui tire profit de ce dynamisme et de cette clarté.
La dissipation thermique est très efficace, et l'ampli reste tiède même après des séances (de rodage) d'une dizaine d'heures d’affilée.
Compter 20-30min de chauffe pour atteindre un son son optimum.
Ça valait vraiment le coup d'attendre :)
Équipe Audiophonics toujours au top!
A vastly improved version of the original Soloist, released in 2015, Burson Audio's Soloist 3X takes up the concept of the original Soloist,...
