DAART AQUILA DAC Headphone Amplifier Preamplifier Balanced AK4497 TPA6120A2 32bit 384kHz DSD
Daart teams have been working on audio solutions with DAC AKM for several years now. Thus, after numerous research, tests and impressive products, the brand pushes its ambitions even further by proposing the Daart Aquila. It is indeed a multifunction device since it combines both a DAC, a headphone amplifier and a preamplifier, all based on a symmetrical design and with an extremely well placed quality/price ratio.
By buying this product you get 79 loyalty points
Reference : 12860
799,00 €tax incl.
665,83 € tax excl.
Daart Aquila
Balanced DAC Headphone Amplifier Preamplifier AK4497 TPA6120A2 32bit 384kHz DSD
Daart Aquila DAC Amplificateur Casque Préamplificateur Symétrique AK4497 TPA6120A2 24bit 384kHz DSD
The best all in one for headphone listening!
A particularly efficient entrance stage
Daart Aquila étage d'entrée
All device inputs, namely USB, Optical and SPDIF support DSD, DoP128 and PCM up to 384kHz. Its small footprint, many features and excellent technical and acoustic features make it an ideal audio device for your headphones or speakers in your HiFi system.
Digital signal processing is provided by an SA8804 chip, supporting DoP64, DoP128, PCM up to 24bit 384kHz via SPDIF and providing ultra-low jitter thanks to the PLL precision clock system. The processed and synchronized signal is then fed to the AK4497 DAC, with an ultra-low noise controller for its analog supply.
On the USB input side Daart turns to an excellent XMOS U8 interface. However, its integrated switching power supply is suppressed and replaced by a low noise linear power supply. An accurate, low-noise dedicated phase clock is also associated with this XMOS. The DSD256 is supported via USB with the Thesycon custom driver, well known for high sound performance and stability.
AOP & PGA
Pour sa section filtre passe-bas (LPF), le Aquila intègre des AOP ultra-faible distorsion OPA1611 et OPA1688. Ceux-ci sont suivi par un autre AOP haut courant faible distorsion OPA1688 en buffer de sortie. Côté traitement des informations, le préamplificateur et le niveau de l'amplificateur casque sont controllés par un PGA2311.
Daart Aquila AOP et FPGA
Une alimentation solide
For its low-pass filter (LPF) section, the Aquila incorporates ultra-low distortion OPA1611 and OPA1688 PDOs. These are followed by another high current low distortion OPA1688 AOP in the output buffer. On the information processing side, the preamplifier and headphone amplifier level are controlled by a PGA2311.
TPA6120 Amplifier for a natural sound
The headphone amplifier is based on a TPA6120 chip offering high performance and rich, natural sound.
In addition, modes are available to adapt the playback to your listening preferences. Mode 1 corresponds to symmetrical mode. Mode 2 offers a sound that is both firm and delicate, often used to listen to classical music. Mode 3 provides softer sound and voice support. Perfect for vocal parts of Jazz for example. In addition, these modes can be combined to find the combination best suited to your listening needs.
Numerous tests for exceptional results
Daart is now recognized for the efforts they make to the quality of sound restitution of their devices. Their ranks include audiophiles, electronic and acoustic engineers and sound engineers. They spend a lot of time testing, listening and analyzing their products in different environments and with different equipment. This allows Aquila to offer not only exceptional measures but also impressive sound reproduction.
Daart Aquila Mesures
DACAKM AK4497EQ
AmplifierTPA6120A2
Sampling rateSPDIF / Optical / AES : DoP128, PCM 24bit 384kHz
USB : DSD256 Native, DoP128, PCM 32bit 384kHz
SNR-130dB
Dynamic range125dB
THD+N0.0003%
Frequency response20Hz - 30 kHz -0.15dB
Crosstalk< -120dB
Balanced output level4.2V
Single Ended headphone amplifier100mW @ 600Ω
180mW @ 300Ω
700mW @ 150Ω
1.5W @ 32Ω
Balanced headphone amplifier200mW @ 600Ω
360mW @ 300Ω
700mW @ 150Ω
1.5W @ 32Ω
THD+N headphone amplifier< 0.001% at max level
Connectors
Inputs1x USB-B
1x AES/EBU (XLR 3 poles)
1x Optical
1x Coaxial
Outputs1x XLR
1x Stereo RCA
1x XLR Balanced
1x Jack 6.35mm
Dimensions248 x 210 x 60mm
Weight4kg
Housing materialAluminium
Input
  • Optical
  • SPDIF
  • XLR
Output
  • Jack 6.35mm
  • RCA
  • XLR
Color
  • Black
Daart teams have been working on audio solutions with DAC AKM for several years now. Thus, after numerous research, tests and impressive products,...
