FOSI AUDIO SK01 Headphone Amplifier
Fosi Audio's SK01 is a high-performance headphone amplifier with good measurements and low distortion. Its output power is up to 2400mW @ 32Ω. It also features numerous equalization potentiometers and two gain levels, enabling it to adapt to all types of headphones and in-ear monitors on the market.
Reference : 18514
89,00 €tax incl.
74,17 € tax excl.
FOSI AUDIO SK01 Portable Headphone Amplifier / Equalizer / Preamplifier
The Fosi Audio SK01 is a high-performance headphone amplifier with good measurements and low distortion. Its output power is up to 2400mW @ 32Ω. It also features numerous equalization potentiometers and two gain levels, enabling it to adapt to all types of headphones and in-ear monitors on the market. Compact, it also features two headphone outputs on 3.5mm jack and 6.35mm jack respectively, as well as a line input and output, both on 3.5mm jack. This gives it a certain versatility in its possible uses: headphone amplifier, preamplifier, or even equalizer for instruments such as a guitar, for example. Fosi Audio's SK01 headphone amplifier is battery-powered and recharges via USB-C connector.
KEY FEATURES:
  • 2400mW @32Ω output power
  • Tone and volume control
  • 2 gain levels
  • Loudness function
  • 6h battery autonomy
Fosi Audio SK01: high-performance headphone amplifier
The Fosi Audio SK01 benefits from a high level of compatibility thanks to its 3.5mm jack and 6.35mm jack headphone outputs, with an output power of 2400mW @ 32Ω (High gain), enabling it to drive headphones with an impedance of 16Ω to 300Ω.
Photo of headphone connection to Fosi Audio SK01
Fosi Audio SK01: versatile equalizer
Thanks to its various potentiometers, you can easily control treble, midrange and bass to personalize your listening experience according to the type of music you're listening to or your preferences. There's also a "Loudness" function for balanced listening at low volume levels.
FOSI AUDIO SK01: Tone setting curve table
Audio Science Review's test of the Fosi Audio SK01
"If this were an ordinary headphone amplifier, objective performance would indicate an average rating. But the addition of tone and volume controls, together with such low levels of noise and distortion, make it subjectively superior to other headphone amplifiers."
Audio science review Logo
Fosi Audio SK01 connectors
Fosi Audio SK01 connectivity diagram
13.5mm headphone output
26.35mm headphone output
3Line input 3.5mm jack
4USB-C power supply
53.5mm jack line output
6LED ignition indicator
7Gain control switch
8Tone control disable switch
9Loudness mode activation switch
10Loudness mode LED indicator
11Treble adjustment
12Midrange adjustment
13Bass adjustment
14Power button / Volume control
Product typeAmplifier / Equalizer Headphones
Inputs1x 3.5mm line input jack
Outputs1x 3.5mm headphone output
1x 6.35mm headphone output
1x 3.5mm aux output
Output powerHigh gain: 2400 mW/32 Ω
Low gain: 300 mW/32 Ω
Gain levelHigh gain: 10dB
Low gain: -10dB
Headphone/In-ear monitors impedance compatibility16Ω - 300Ω
Frequency response20Hz - 20kHz (±0,5 dB)
THD+N0.001% (@ 1kHz 770mV)
SNR≥ 108dB
power supply5VDC via USB-C
Battery autonomy6h
Dimensions121 x 51x 43mm
Net weight290g
Package1x Headphone amplifier Fosi Audio SK01
1x USB-A/C to USB-C cable
InputJack 3.5mm
OutputJack 3.5mm
OutputJack 6.35mm
ClassN/A
2 reviews
Super ampli casque
Je recommande cet ampli casque
Qualité des matériaux et de l'assemblage top
Facilité d'utilisation
Avec toutes ses fonctions il est un vrai "couteau Suisse".
La son est très bon et les différents réglages efficaces.
Et tout ça pour un prix très raisonnable.
J'ai vraiment été bluffé par les qualités de cet ampli.
Je recommande également Audiophonics.
Ce sont des passionnés et ça se voit sur les pages produits du site et sur le blog.
Ça se voit aussi au traitement des commandes qui est top.
Merci à l'équipe
This review has been posted for FOSI AUDIO SK01 Portable Headphone Amplifier / Equalizer / Preamplifier
Correct
Ecoute neutre et homogène mais pas ennuyante . Correction des fréquences pas caricatural . Appareil peu encombrant . Rien de rédhibitoire pour le prix . Si l'on ne veux pas se ruiner c'est un appareil à la restitution honnête mais qui ne rivalisera pas avec des appareils plus haut de gamme .
Fosi Audio's SK01 is a high-performance headphone amplifier with good measurements and low...
