With its SK02, Fosi Audio unveils a small, versatile, high-performance device that takes up the form factor of its SK01. The SK02 fulfills the functions of headphone amplifier, portable preamplifier and portable DAC. The SK02 features an ES9038Q2M DAC chip and a low-noise, high-speed SGM8262 operational amplifier chip. This enables the SK02 to support high-resolution streams up to PCM 32bit 384kHz and DSD256, with output power up to 1100mW. It also features gain control (High and Low) to adapt to headphones with impedance ranging from 16 ohms to 300 ohms. Regarding inputs, the SK02 features USB-C and Toslink optical connectivity. Outputs include a 3.5mm jack and 4.4mm balanced jack headphone outputs, plus a 3.5mm jack/mini-Toslink auxiliary output for connection to an amplifier.
The SK02 incorporates an ES9038Q2M DAC chip from ESS Technology. This 32bit stereo DAC is a high-performance chip specially designed for audiophile applications. It is based on HyperStream II architecture and enables the Fosi Audio SK02 to support 32bit 384kHz PCM and native DSD streams up to DSD256.
The SK02 is capable of developing substantial headphone output power. Using an SGM8262 operational amplifier, its 3.5mm jack output reaches up to 280mW @ 32Ω of power, and its 4.4mm balanced jack output reaches up to 1100mW @32Ω of power, all while maintaining a THD < 0.001%. Two gain modes enable the SK02 to adapt to all types of headphones with impedance between 16Ω and 300Ω.
An auxiliary output on a 3.5mm jack/mini-Toslink connector also allows the SK02 to be coupled to an amplifier. This transforms the SK02 into a portable preamplifier. If you're using the USB-C input, you'll need to use a 3.5mm jack as output, while if you're using the Toslink input you'll need to use a mini-Toslink connector for the SPDIF signal.
The top of the SK02 features several LED indicators. They make it easy to locate essential information about the current playback, such as sample type, gain setting and selected input mode.
A large knob/potentiometer gives you access to the SK02's essential settings and controls.
Turn the potentiometer for precise volume adjustment.
Simply click on the button to access the play/pause function.
Double-click to mute current playback.
| 1 | Input source selection |
| 2 | Gain selection: High / Low |
| 3 | LED indicators |
| 4 | Multifunction button |
| 5 | 3.5mm jack headphone output |
| 6 | Balanced 4.4mm headphone output |
| 7 | USB-C input / 5V DC power supply |
| 8 | AUX jack 3.5mm/mini-Toslink output |
| 9 | Toslink optical input |
| Specifications | |
| Product type | Headphone amplifier / Potable Preamplifier / Portable DAC |
| DAC chip | ES9038Q2M |
| Amplification chip | SGM8262 |
| Inputs | 1x USB-C input 1x Optical Toslink input |
| Outputs | 1x 3.5mm jack headphone output 1x 4.4mm balanced jack headphone output 1x AUX jack 3.5mm/mini-Toslink output |
| Supported sampling rates | USB: PCM 32bit 384kHz, native DSD up to DSD256 Toslink optical: PCM 24bit 192kHz |
| Gain adjustment | |
| Headphone output power | 3.5mm headphone output: 90mW @ 32Ω (Low gain) / 280mW @32Ω (High gain) Balanced 4.4mm headphone output: 350mW @ 32Ω (Low gain) / 1100mW @32Ω (High gain) |
| Recommended headphone impedance | 16Ω-300Ω |
| Frequency response | 20Hz-20kHz (+/-0.02dB) |
| SNR | 3.5mm jack headphone output: 110dB (Low gain) / 116dB (High gain) Balanced 4.4mm jack headphone output: 102dB (Low gain) / 113dB (High gain) |
| THD | > 0.001% |
| Noise level | 3.5mm jack headphone output: 6.2uV Balanced 4.4mm headphone output: 13uV |
| Crosstalk | 3.5mm jack headphone output: 110dB (Low gain) / 118dB (High gain) Balanced 4.4mm headphone output: 103dB (Low gain) / 104dB (High gain) |
| General | |
| Power supply | 5V DC via USB-C |
| Dimensions | 121 x 51x 43mm |
| Weight | Approx. 300g |
| Color | Black |
| Package | 1x Fosi Audio SK02 portable DAC headphone amplifier 1x USB-A/C to USB-C cable |
| Input | Optical |
| Input | USB |
| Output | Jack 4.4mm |
| Output | Jack 3.5mm |
| Output | Optical Mini-Toslink |
| DAC / ADC Chip | ES9038Q2M |
| Max sampling rate | DSD256 |
| Max sampling rate | 384kHz |
| Color | Black |
| Class | N/A |
| Networking | No |
| Remote Control | No |
