FURUTECH ADL Cruise Amplifier Headphone / DAC 24bit / 96khz
By buying this product you get 98 loyalty points
Reference : 6796
499,00 €tax incl.
415,83 € tax excl.
This resolutely high-end headphone amplifier features a battery for both nomadic and sedentary use.
Powerful and versatile it will be perfect to amplify the most demanding helmets (600 ohms).
Delivered in a Carbon / Aluminum case and not exceeding 200g it will quickly become the perfect companion for quality roaming.
It is powered by a transformer supplied or a USB port
Features:/ Strong>
  • Output: Jack 3.5mm
  • Input: Line In (3.5 mm Jack) x 1
  • USB input: (mini B type) x 1
  • Signal to Noise Ratio: Line in: 100dB / USB in: 96dB /
  • DAC: WM8716 192kHz / 24bit
  • USB: TE7022L 96kHz / 24bit
  • (600 ohm) 16mW (600 ohm) 23mW (300 ohm) Output Type Headphone Output (Max): 1% THD 1kHz / 78mW (12 ohm) 94mW (16 ohm)
  • Frequency response: Line input: 20Hz ~ 20kHz (± 0.5dB) Headphone output / USB input: 20Hz ~ 20kHz (± 0.5dB) Headphone output
  • Channel separation: 60dB (1KHz)
  • Harmonic distortion: 0.02% (1KHz line input)
  • Power Supply: DC5V, 2000mA, 10W Switching
  • Reading time: more than 80 at maximum load (5 hours charge)
  • Dimensions: (W) x 120 (D) x 28 (H) mm
  • Battery: DC3.7V, 940mAh Li-ion
  • Weight: 198g
Test in English CNET (PDF)
https://www.audiophonics.fr/images2/6796/6796_FURUTECHADLCRUISE_1.jpg
https://www.audiophonics.fr/images2/6796/6796_FURUTECHADLCRUISE_2.jpg
https://www.audiophonics.fr/images2/6796/6796_FURUTECHADLCRUISE_3.jpg
InputJack 3.5mm
OutputJack 3.5mm
