By buying this product you get 34 loyalty points
HiFiMAN's EF499 is a DAC and headphone amplifier. It offers warm sound from R2R digital/analogue conversion and an output level of 4.35W at 32Ω, enabling it to drive a wide range of headphones. Its extensive connectivity makes it a highly flexible device, capable of fitting into a wide range of configurations.
For the EF499's digital/analogue conversion stage, HiFiMAN has chosen an R2R ladder resistor network. This 100% analogue conversion method produces a naturally warm sound, very close to the Hymalaya DAC, and as such, very close to the brand's characteristic sound. You can also choose whether or not to activate a NOS (Non-oversampling) mode.
Moreover, in addition to R2R conversion, the EF499 offers amplification of 4.35W into 32Ω in balanced output and 1.28W into 32Ω in single-ended output. Furthermore, two gain settings are also available, enough to drive the vast majority of headphones on the market, including the most demanding high-impedance ones.
The EF499 from HiFiMAN offers a range of connections for great flexibility in use, thanks in particular to the digital inputs available. In addition to a coaxial input, the EF499 offers a USB-B and USB-C input as well as an RJ45 input, allowing you to connect a router, for example. On the output side, in addition to the 4-pin XLR and 6.35mm jack headphone outputs available on the front panel, a 3-pin stereo XLR and stereo RCA output are also available on the rear panel, allowing you to use it as a DAC and preamplifier in conjunction with a power amplifier.
The HiFiMAN EF499 features an RJ45 Ethernet network port. Thanks to this, you can connect the EF499 to a NAS connected to your network to enjoy your favorite audio files. Thanks to its wireless streaming function, you can also enjoy your music directly from your portable players. You can also enjoy your music from your favorite applications by connecting them to your router and then to the amplifier.
Type of product | Headphone amplifier DAC |
Inputs | 1x Coaxial 1x USB-B 1x USB-C 1x RJ45 |
Outputs | 1x Balanced XLR 4-pin headphone output 1x Single-ended 6.35mm jack headphone output 1x Balanced stereo XLR 1x Single-ended stereo RCA |
DAC | R2R |
THD+N | 0.008% |
Channel separation | 95±3cB |
Signal-to-noise ratio (SNR) | 99dB |
Output power | Balanced output : 4.35W @ 32Ω Single-ended output : 1.28W @ 32Ω |
Power supply | 100V-120V AC 60Hz 210-230V AC 50Hz |
Weight | 3.3kg |
Color | Black |
Package | 1x HIFIMAN EF499 1x Power cable |
Input | SPDIF |
Input | USB |
Input | RJ45 |
Output | XLR |
Output | RCA |
Output | Jack 6.35mm |
Max sampling rate | NC |
Color | Black |
Class | N/A |
Networking | No |
Remote Control | No |
