HIFIMAN MINI SHANGRI-LA Electrostatic Headphone Amplifier
The HiFiMAN Mini Shangri-La amplifier has been specially designed to drive electrostatic headphones. Its amplification stage uses two MOSFET transistors (metal-oxide-semiconductor field-effect transistor) in a symmetrical design. Its independent high-voltage power supply stage is equipped with an independent power supply regulator, guaranteeing perfectly silent power supply. Finally, optimised placement of the various components on the PCB reduces interference, resulting in even more transparent sound reproduction.
By buying this product you get 166 loyalty points
Reference : 19426
1 669,00 €tax incl.
1 390,83 € tax excl.
Shipping date: 22-04-2025.
HiFiMAN Mini Shangri-La Electrostatic Headphone Amplifier
Mini Shangri-La : Front view
HiFiMAN Mini Shangri-La : Symmetrical architecture
The Mini Shangri-La's four-channel differential structure incorporates a switch, a buffer and a low-pass filter, effectively supporting the unit's balanced outputs while offering excellent audio quality.
Mini Shangri-La : operating diagram
Description diagram
Mini Shangri-La :explanatory diagram
1Input selector
2Output for electrostatic headphones
3Volume control
4Stereo RCA input
5Stereo XLR input
6Power socket
7Voltage selector
8Power switch
Inputs1x RCA stereo
1x XLR stereo
Outputs2x Electrostatic headphone outputs
Dimensions255 x 251 x 93mm
Weight5.82kg
Package1x HiFiMAN Mini Shangri-La amplifier
1x Power cord
InputXLR
Output5-pin electrostatic headphone connector
ColorSilver
ClassN/A
The HiFiMAN Mini Shangri-La amplifier has been specially designed to drive electrostatic headphones. Its amplification stage uses two MOSFET...
