HIFIMAN PRELUDE Headphone Amplifier / Preamplifier
With the Prelude, HIFIMAN presents a balanced Class A headphone amplifier based on MOSFET transistors to deliver natural sound reproduction and 10W of power at 32Ω.
By buying this product you get 266 loyalty points
Reference : 20456
2 660,00 €tax incl.
2 216,67 € tax excl.
HIFIMAN Prelude Discrete Class A Balanced Headphone Amplifier / Preamplifier 10W 32Ω
Hifiman Prelude : Front view
HIFIMAN Prelude : Class A amplification
The Prelude features Class A amplification based on MOSFET transistors in a fully discrete balanced circuit. To take full advantage of this architecture, the circuit incorporates a signal balancer, transforming the RCA input signal into a fully balanced signal, drastically reducing noise and interference. The result is a natural-sounding signal with a power handling of 10W at 32Ω.
HIFIMAN Prelude : Channel balance
To achieve precise control over channel balance for its pre-amplifier, HIFIMAN uses a 4-voice potentiometer from ALPS, known for its high quality and precision, enabling the brand to fine-tune this parameter without coloring the sound in any way.
HIFIMAN Prelude : Low-noise power supply
Specially designed for the Prelude, the high-power, low-noise toroidal transformer provides a clean, stable power supply at all levels of the headphone amplifier, helping to improve the quality of the final output. The amplifier housing is made from a single piece of aluminum, isolating harmful resonances that can degrade audio performance, guaranteeing a clean sound output.
Overview of HIFIMAN  Prelude
Hifiman Prelude: diagram
1XLR/Jack 6.35mm output
2Input selector
3Gain selector
4Output selector
5XLR 4-pin output
64.4m jack output
7Volume control
8RCA inputs
9Power supply connector
10XLR Pre-amp output
11Pre-amp RCA output
12XLR input
Preamplifier
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Outputs1x Combo XLR balanced / 6.35mm jack single-ended
1x XLR 4-pin balanced
1x Balanced 4.4mm jack
1x Balanced XLR pre-amp output
1x Single-ended RCA pre-amp output
Frequency response20Hz-50kHz
Signal-to-noise ratio (SNR)-113dB @ 1kHz
Total harmonic distorsion more noise(THD+N)0.0009% @ 1kHz, low gain
Power output10W @ 32Ω
6W @ 64Ω
2.5W @ 150Ω
1W @ 300Ω
560mW @ 600Ω
Power supply voltage220V AC 50/60Hz
Power consumption< 50W
Dimensions330 x 56 x 260mm
Weight6.5kg
Package1x HIFIMAN Prelude
1x Power cord
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
ClassClass A / AB
HIFIMAN PRELUDE Discrete Class A Balanced Headphone Amplifier / Preamplifier 10W 32 Ohm
With the Prelude, HIFIMAN presents a balanced Class A headphone amplifier based on MOSFET transistors to deliver natural sound reproduction and 10W...
