By buying this product you get 321 loyalty points
Class A Discrete Balanced Headphone Amplifier
The Holo Audio Bliss Level 1 is a discrete, high-end pure Class A headphone amplifier, offering incredible sound quality thanks to a design based on an optimized and careful architecture, using only high-end electronic components. It also allows to develop an important power of 12W under 32Ω, making it able to accompany any headphone of the market without difficulty.
The Bliss Level 1 has single-ended stereo RCA and single-ended stereo XLR inputs. The device has three headphone outputs on its front panel, with single-ended Jack 6.35mm as well as balanced XLR 4 pins and Jack 4.4mm. The rear of the unit also features a single-ended stereo RCA and balanced stereo XLR output.
Please note: power cable not included.
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Product type | Headphone amplifier |
Inputs | 1* Single-ended stereo RCA 2* Balanced stereo XLR |
Outputs | 1* Single-ended Jack 6.35mm headphone output 1* Balanced Jack 4.4mm headphone output 1* Balanced XLR 4 pins headphone output 1* Single-ended stereo RCA 1* Balanced stereo XLR |
Output power | 12W @ 32Ω |
Consumption | 60W |
Dimensions (W*D*H) | 430*300*67mm |
Weight | 18kg |
Color | Black and coper |
Package | 1x Holo Audio Bliss Level 1 1x Power cable |
Input | XLR |
Input | RCA |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
Output | RCA |
Output | XLR |
Color | Copper |
Color | Black |
Class | Class A / AB |
Remote Control | No |
