ifi Audio pro iCAN Valve Preamplifier / Headphone Amplifier
By buying this product you get 224 loyalty points
Reference : 11024
2 249,00 €tax incl.
1 874,17 € tax excl.
The new ifi AUDIO ICAN PRO SIGNATURE is available.
IFi Pro iCAN Headphone Amplifier and Headphone Amplifier is the epitome of the brand's expertise, supported by the prestigious AMR company. Based on a hybrid transistors and tubes circuit, iFi Pro iCAN embodies the best of both technologies and not a caricatured compromise.
One can thus choose the sound as desired by inserting in the circuit the tube sound or only transistor.
The stereo input is on a JFET transistor stage with very low distortion accompanied by a bipolar stage seconded by a Mosfet class A stage. The tube stage is amplified by two 5670 GE closer to the ALPS potentiometer "Black Beauty "with 6 tracks in true symmetrical mode.
Thus theiFi pro iCAN stereo preamplifier is fully symmetrical from input to output on a 4-layer circuit board.
The Chéma of the totally optimized circuit in coupled current mode does not include any capacitors on its path which could degrade the original signal.
Only components sorted on the shutter are in this preamplifier: Vishay MELF capacitors, TDK COG for the audio part, Elna Silmic II and Panasonic Foil for the power supply.
This symmetrical stereo preamplifier is a studio quality level headphone amplifier capable of delivering a very high power (14000mW) for "driver" any of the most demanding symmetrical audiophile model including models from Sennheiser, Audeze and Hifiman.
As any high-end headphone amplifier the gain is fully adjustable on three positions: 0dB, 9dB, 18dB.
Logo On Top Audio
IChat iCan Headphone amp test by ON-Topaudio
iFi Audio Pro iCAN review by Qobuz
" The iFi Pro iCAN is an amplifier that offers just about anything a demanding amateur in terms of power or connectivity can want and also wants to enjoy various types of amplification, all of which offer different sound qualities but quality, with or without bass enhancement and/or spatialization effect, these options being also available on its pre-amplified outputs. "
Test Qobuz
Presentation video of iFi Audio Pro iCAN:
Technical characteristics :
  • Gain: 0dB, 9dB, 18dB selectable by switch.
  • 2 tubes 5760 GE.
  • Frequency response: 0.5Hz to 500kHz (-3dB)
  • Total harmonic distortion: Transistor stage: ≤0.0015% ≤0.005%, Tube +: ≤0.012% ≤0.2%.
  • Signal Noise Ratio (balanced / unbalanced mode):> 147dB (A) /> 137dB (A).
  • Output power (16Ω, balanced / unbalanced):> 14,000mW /> 4,800mW.
  • Voltage level for 600 Ω, balanced / unbalanced):> 23V /> 11.5V.
  • Average power consumption: ≤ 22W, 50W max.
Inputs and outputs:
  • Three stereo RCA stereo asymmetric inputs.
  • One XLR balanced input.
  • A variable XLR balanced output.
  • An unbalanced RCA-plated RCA output.
  • Two headphone outputs on a 6.35mm jack switchable into a stereo output.
  • One headphone output on 4 pins symmetrical.
  • An asymmetrical TRS 3.5mm jack output.
  • A balanced TRS 3.5mm jack output.
Dimensions:
  • Dimensions: 213x 192.5 x 63.3 mm
  • Weight: 6kg
InputXLR
OutputJack 6.35mm
ColorSilver
ClassTube amp
