By buying this product you get 104 loyalty points
Headphone Tube Amplifier
The La Figaro 339i headphone amplifier is a high-end model, benefiting from a perfectly designed. Its first order direct amplifier stage and cathode output allow it to deliver rich, dense and precise sound, while offering a significant energy reserve, allowing it to accompany demanding headphones with impedance up to 600Ω. Numerous on-board components ensure an improvement in sound quality and an increase in the output level of the preamplification stage. Overall, the 339i is optimized to provide the most transparent sound reproduction possible. The whole unit is integrated in a magnificent and robust Aluminium chassis, perfectly highlighting the two large tubes of the unit.
Product type | Headphone amplifier |
Input | 1x Line input on stereo RCA |
Outputs | 1x Line output on stereo RCA 1x Jack 6.35mm / XLR 3 pins combo connector |
Recommended headphone impedance | 32-600Ω |
Frequency response | 10Hz - 30kHz ±1dB |
SNR | > 100dB |
Output power | > 0.6W |
Package | 1x La Figaro 339i 2x Power cable |
Color | Case : Black |
