LITTLE DOT LD1 + WE408A Headphone Amplifier
Reference : 4783
179,00 €tax incl.
149,17 € tax excl.
Little Dot I + Tube Amplifier
The LD1 + is available with 3 types of inlet tubes:
  • Basic with 6J1 tubes
  • Improved with EF92 tubes
  • Luxury with tubes WE408A
We sell it directly in its improved version with tubes W408A
The amplifier has 2 switches which allow to adapt one of these 3 models of tubes:
Tubes 138/5654 / EF95 / 6J1, EF91 / EF92 / CV131 or WE408A / WE403A
On the LD1 + the output stage uses discrete components (transistors) so it is naturally more comfortable with low impedance headphones unlike the MKII
Compatible with helmets from 8 to 600ohm.
1 year warranty
Features:/ Strong>
  • 2 RCA inputs
  • Output: headphone jack 6.35
  • Distortion:
    0.2% (output: 1 V eff 1000Hz)
    0.6% (output: 3 V eff 1000Hz)
    1.0% (output: 5 V eff 1000Hz)
  • Signal to noise ratio: 92 dB
  • Frequency response: 10Hz - 50kHz (-3dB)
  • Output Power:
    800mW (32 Ohm)
    300 MW (120 Ohm)
    150mW (300 Ohm)
  • Amplification:
    Gain on HIGH: 6.5
    Gain on LOW: 3.25
  • CoNsumption: 15 VA
  • Size: 180 x97x10 (h) mm
  • Weight: 1.5 kg
OutputJack 6.35mm
ClassTube amp
6 reviews
Une surprise
appareil bien en emballé , look sympa compact , alors au moment de la mise en route et après une petite chauffe , place à l'écoute , une cata
This review has been posted for LITTLE DOT LD1 + WE408A Headphone Amplifier
My first tube amp
I am very happy with this little amp.
There is a perfect synergy with my Grado Headphones especially the RS1X but it is also very good with Beyerdynamic dt1990pro there is plenty of power that this amp deliver (more power than I will ever need) I just love tube sound - everything sounds so natural I have not experienced this with my any of my solid state amps.
This amp sounds fantastic delivery and send was fast and reliable I will be back in the future for sure.
Highly recommended !
Excellent
M'a fait apprécier mon casque que je trouvais trop bassy. Ma config est composé d'un PC optimisé avec un DAC/Ampli casque Atoll HD100 et du casque Fostex TH600; Je trouvais l'ensemnle trop bassy sur certains type de musque. J'ai donc intercallé le Little Dot entre l'Atoll et le casque.
Enfin de la souplesse !
C'est un super gain en ce qui concernle ma config.
IMPECC
Ce petit ampli joue son rôle avec beaucoup de talent pour restituer un son de qualité venant de mon PC vers mon casque. Ne pas hésiter à le laisser chauffer un peu et ensuite à monter le volume. Le son est punchy et chaleureux et le Little Dot 1 efface un peu l'aspect métallique du son numérique ou Mp3 à dispo sur le web. L'écoute est très subjective et personnelle à chacun et donc il faudra trouver le bon casque qui correspond à l'ampli et à l'oreille. J'en ai essayé plusieurs AKG240, Shure, etc, et en fait celui qui me correspond le mieux dans cette configuration est le Sennheiser HD238, petit casque léger, confortable et suffisamment puissant pour cette utilisation.
Ce petit ampli qui ne paye pas de mine avec une carte son genre Asus Xonar Essence pour lui envoyé un signal de qualité s'est une véritable turie avec un signal en 24/96kHz pour peu qu'on est un bon casque (perso j'ai un HD 598 Sennheiser) il est vraiment capable de descendre dans les infra avec un peunch de tous les diables avec des attaques diabolique tout en restant hyper linéaire et un médium soyeux (ha les lampes je quif). Par contre je fais un essai avec une carte son Creative s'est une véritable catastrophe aucune basse sa tire dans l'aigu comme pas possible mais si l'on met un bond dac au cul là sa change du tout au tout. Vraiment à conseiller à seux qui ont un petit buget, ils ne seront pas déçus. Très agréable de l'avoir près de son PC pour un son de très haute volé au casque.
