LOXJIE P20 Balanced Tubes Headphone Amplifier 2x 6N3 Black
The Loxjie P20 is a small balanced tube headphone amplifier. It carries a pair of high-quality 6N3 tubes mounted on a high-performance and perfectly calibrated amplification circuit, allowing it to achieve a low level of distortion.
4.0 / 5
Reference : 13829
99,00 €tax incl.
82,50 € tax excl.
Loxjie P20
Loxjie P20 Amplificateur Casque Symétrique à Tubes 2x 6N3
The Loxjie P20 is a small balanced tube headphone amplifier. It carries a pair of high-quality 6N3 tubes mounted on a high-performance and perfectly calibrated amplification circuit, allowing it to achieve a low level of distortion. Its balanced inputs and outputs will allow you to take full advantage of your also balanced headphones.
AVolume knob
BScreen
CSingle-ended headphone output
DBalanced headphone output
EBalanced input
FSingle-ended input
GPower supply connector
A coherent and efficient product
The entire device benefits from a careful and optimized design. The potentiometer allows both volume control and menu navigation, while significantly reducing the noise generated. This potentiometer is associated with a JRC NJW1195 volume control chip, providing a very high SNR and low distortion to allow your music to play down to the last detail. All components are integrated in a robust black CNC machined Aluminium housing. The P20 also includes a series of 4 JRC55320 PDOs.
Amplification typeTubes
PowerSingle-ended385mW @ 32Ω
210mW @ 64Ω
105mW @ 150Ω
55mW @ 300Ω
29mW @ 600Ω
Balanced425mW @ 32Ω
665mW @ 64Ω
565mW @ 150Ω
325mW @ 300Ω
175mW @ 600Ω
THD+NSingle-ended0.02%
Balanced0.006%
SNRSingle-ended97dB
Balanced102dB
Case materialCNC machined Aluminium
Consumption10W
Standby consumption0.5W
Dimensions148 x 70 x 128mm
Weight600g
Power supply included-
InputXLR
OutputJack 6.35mm
OutputJack 3.5mm
ClassClass A / AB
Impeccable ampli casque(s)
Son neutre et parfait sur des casques même haut de gamme ( Sennheiser HD600 etc..) Fabrication impeccable. Entrées et sorties symétriques rarissimes à ce prix. Consommation testée : 9,9 watts. Aucun bruit de fond audible.
This review has been posted for LOXJIE P20 Balanced Tubes Headphone Amplifier 2x 6N3 Black
The Loxjie P20 is a small balanced tube headphone amplifier. It carries a pair of high-quality 6N3 tubes mounted on a high-performance and...
