MATRIX M-STAGE HPA-2 USB Headphone Amp / DAC / ClassA Silver Preamp
By buying this product you get 34 loyalty points
Reference : 8257
349,00 €tax incl.
290,83 € tax excl.
MATRIX M-STAGE HPA-2 (USB) Headphone Amplifier ClassA Silver 24bit / 192kHz
New version of the M-Stage
Matrix offers us a well-finished headphone amplifier, which of course offers a headphone output, but also a line output, to be used in pre-amp.
These two outputs are polarized in Class A , guaranteeing a very good restitution.
Both outputs can be used simultaneously.
Two inputs are available and can be selected using a button on the front panel.
This new version of the M-Stage is equipped with the now famous XMOS USB module with a sampling rate of 24Bit / 192kHz, and two qualitative components: the PCM1793 converter and the OP-AMP LME49720.
Characteristics :
  • XMOS USB interfaces (100% asynchronous)
  • Frequency response: 10Hz (-0.3dB) to 35kHz (-1dB)
  • SNR:> 95dB gain at 0 dB
  • Distortion: <0.001% at 6mW / 300Ω
  • Headphone output power: 200mW / 300Ω, 400mW / 60Ω
  • Headphone Output Impedance: 5Ω
  • Line Output Impedance: 60Ω
  • RCA Input Impedance: 47kΩ
  • Sampling rate: 16-24Bit / 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
  • Compatible: WindowsXP / Vista / 7/8 / 8.1, Mac OS X10.6.4 Mac OS X10.6.4 and +
  • Voltage: AC 110V-120V 50 / 60Hz AC 220V-240V 50 / 60Hz
  • Power Consumption: <15W </ Li>
  • Dimensions: 280 × 115 × 50mm (W × W × H)Weight: 1.4 kg
  • Accessories :
    • Power cable × 1Driver and Manual × 1 </ Li>
https://www.audiophonics.fr/images2/8257/8257_matrix_m-stage_amplifier_6.jpg
</ P>
</ P>
https://www.audiophonics.fr/images2/8257/8257_matrix_m-stage_amplifier_5.jpg
</ P>
</ P>
https://www.audiophonics.fr/images2/8257/8257_matrix_m-stage_amplifier_4.jpg
</ P>
https://www.audiophonics.fr/images2/8257/8257_matrix_m-stage_amplifier_7.jpg
</ P>
https://www.audiophonics.fr/images2/8257/8257_matrix_m-stage_amplifier_3.jpg
