The M-Stage is back in a new edition with a devastating look.
Class A, 100% symmetrical this new iteration takes again the characteristics that made the success of these predecessors while improving them.
the HPA-3B is part of its dual mono structure and its high power the ideal complement of any high-end headset demanding.
Equipped with standard XLR stereo inputs, the unit comes with adapters for direct use on unbalanced (RCA) sources.
Connectors:
- Input: XLR stereo
- Outputs: 4-pole XLR, 6.35mm stereo jack
Features:/ P>
- Symmetrical headphone output (XLR):
SNR> -114dB Class A
THD + N <0.0003% at 300ohms 135mW 1kHz Class A
Frequency response: 20Hz-20kHz (+ 0dB / -0.05dB)
Output Impedance: 0.6ohms
Output power: 3800mW at 33ohms / 1500mW at 300ohms / 800mW at 600ohms at THD + N = 0.01%
- Output Headphone asymmetrical (jack 6.35):
SNR> -108dB Class A
THD + N <0.0004% at 300ohms 325mW 1kHz Class A
Frequency response: 20Hz-20kHz (+ 0.03dB / -0.1dB)
Output Impedance: 0.4ohms
Output power: 2100mW at 33ohms / 430mW at 300ohms / 220mW at 600ohms at THD + N = 0.01% - Gain Settings:
Gain: 5 = 5dB 10 = 10dB 20 = 20dB - Consumption:
<25w br="">Fuse: AC250V / 500mA 5x20mm - Dimensions
285 × 142 × 49mm W × W × H
Weight: 1.7kg - Accessories :
User manual on CD × 1
Power cord × 1
XLR / RCA Adapter × 2
