MONOLITH LIQUID SPARK Amplificateur Casque 1.3W 50 Ohm
The Monolith Liquid Spark is a compact headphone amplifier developed by Alex Cavalli for Monolith. This device uses two filtered 18V power rails allowing to develop a high power output and therefore offering a generous headroom.
4.0 / 5
Reference : 14508
159,00 €tax incl.
132,50 € tax excl.
The power supply is supplied with a US-standard power cord, you must use a US to FR Adapter to use it on European plugs.
Monolith Liquid Spark Amplificateur Casque 1.3W 50 Ohm Monolith Liquid Spark Amplificateur Casque 1.3W 50 Ohm
The Monolith Liquid Spark is a compact headphone amplifier developed by Alex Cavalli for Monolith. This device uses two filtered 18V power rails allowing to develop a high power output and therefore offering a generous headroom. It is able to deliver 1300mW RMS at 50 Ohm, with a very low distortion level and an adjustable gain, to fit most headphones on the market.
Design par Alex Cavalli
For over 18 years now, Alex Cavalli has been designing and developing audio circuits, with a particular focus on headphone amplifiers. Formed in 2011 with the desire to create exceptional products, Cavalli has been behind some of the most renowned headphone amplifiers of the last decade, such as the Liquid Fire, Liquid Gold, Liquid Crimson and Liquid Glass. These amplifiers are known for their extremely precise sound reproduction, unique designs and their ability to reproduce incredible musicality.
The Liquid Spark uses a DC topology coupled from input to output, meaning that no capacitors are integrated in the signal path. In addition, many amplifiers in this price range use AOPs, implying a different signature and requiring a high level of feedback. The Liquid Spark benefits from a totally discrete design, without AOPs, allowing for an exceptionally transparent sound reproduction.
Exceptional design
The Liquid Spark uses laser-matched low-noise audio JFETs for its differential input stage and high-performance MOSFETs for its output stage, offering pure amplification and allowing you to enjoy a nice power reserve in a small format.
Preamplifier output
The Monolith Liquid Spark integrates a stereo RCA output, controlled by a volume control, allowing for use with an external amplifier or active speakers.
Input1x Single ended stereo RCA
Outputs1x Jack 6.35mm headphone output
1x Stereo RCA preamp output
POwer1.3Wrms @ 50 Ohm
Max power2.4W @ 33 Ohm
1.531W @ 56 Ohm
0.614W @ 150 Ohm
0.314W @ 300 Ohm
Frequency response10Hz - 50kHz +/-0.05dB
THD+N (@ 1 kHz)0.0017% @ Output 1Vrms, 33 Ohm
0.0019% @ Output 5Vrms, 33 Ohm
IMD CCIF0.0002% @ Output 1Vrms, 33 Ohm
0.001% @ Output 5Vrms, 33 Ohm
IMD SMPTE0.0003% @ Output 1Vrms, 33 Ohm
Noise (Relative to 1Vrms)-102dB @ Gain = 3x
-96dB @ Gain = 6x
Output impedance< 0.09 Ohm
Crosstalk< -83dB @ 1kHz, Output 1Vrms, 33 Ohm
Channel balance0.3dB @ pot at unitary gain
Gain+3dB
+6dB
Power supply36VDC 1.25A (power adapter included)
Housing materialAluminium
Dimensions117 x 94 x 38mm
Weight271g
ColorSilver
Input
  • RCA
Output
  • Jack 6.35mm
  • RCA
Color
  • Silver
Class
  • N/A
Remote Control
  • No
Monolith liquid spark
Reçu récemment, il y a dix jours. J ai dû attendre patiemment le réapprovisionnement de celui-ci,une vingtaine de jours. C'était un peu long mais cela en valait la peine. C'est mon premier ampli casque, j'utilisais avant la sortie casque de mon sansui ta 300 receiver. Je dois dire que je suis très satisfait de mon achat, cet ampli a une très bonne sonorité, est très musical et détaillé, les basses descendent très bas avec un très bon contrôle et beaucoup d'impact, très agréable avec la contrebasse. Le son est très équilibré je trouve, les aigus ne sont pas du tout agressifs sans luminosité excessive, très agréable à écouter et pas du tout fatiguant même après de longues heures d'écoutes. J'ai longtemps hésité entre celui-ci et le topping L30, j'ai opté pour celui-ci car il n'a pas d'ampli op et n'a pas de condensateur dans le chemin du signal. Je l'utilise avec un casque AKG impédance 32 ohms avec succès, celui-ci est bien drive par ce petit Monolith liquid spark. Belle synergie entre les deux.
En conséquence je conseille vivement cet ampli casque pour ceux qui ont un budget entre 100 et 150 €, et souhaite avoir un ampli casque agréable à écouter.
Seb.
This review has been posted for MONOLITH LIQUID SPARK Amplificateur Casque 1.3W 50 Ohm
The Monolith Liquid Spark is a compact headphone amplifier developed by Alex Cavalli for Monolith. This device uses two filtered 18V power rails...
