MONOLITH LIQUID SPARK DAC AK4493 XMOS 32Bit 192kHz DSD128
The Monolith Liquid Spark DAC is a compact digital/analog converter developed by Alex Cavalli. It offers excellent audio quality and is especially designed to work in conjunction with the Monolith Liquid Spark headphone amplifier.
Reference : 14962
139,00 €tax incl.
115,83 € tax excl.
Monolith Liquid Spark DAC AK4493 XMOS 32bit 192kHz DSD128
This DAC uses an AKM AK4493EQ conversion chip, a 32bit XMOS XU208 32bit multi-core USB microcontroller and ultra-low phase noise clock for outstanding sound and performance. As a result, this DAC will enable you to significantly improve the sound reproduction of a computer, smartphone, tablet or other digital playback device.
Designed by Alex Cavalli
Alex Cavalli has focused on audio circuit design and engineering, particularly headphone amplifiers, for over 18 years. Trained in 2011 with a particular passion for DIY, he is eager to offer exceptional products. He has created some of the most acclaimed headphone amplifiers of the last decade, including Liquid Fire, Liquid Gold, Liquid Crimson and Liquid Glass. His audio devices are known for their smooth yet extremely accurate sound reproduction, as well as their unique designs and ability to deliver great musicality.
AKM AK4493EQ DAC
The AKM AK4493 digital/analog conversion chip is the new 32bit stereo flagship of the brand. It supports PCM streams up to 768kHz and DSD up to DSD128. An internal circuit incorporates a brand new 32bit digital filter for ultimate sound reproduction and musicality.
All the digital inputs you need
The Liquid Spark DAC offers rich connectivity to adapt to the needs of each user. It has USB, Coaxial and Optical inputs, allowing you to connect all your digital peripherals.
Monolith Liquid Spark DAC review by Audio Science Review (Amir)
" The measurements of the Spark DAC by Alex Cavalli is uneventful which is what I like to see. It slots right in with its competitors providing an alternative with different form factor, look, brand and support. "
Test du Monolith Liquid Spark DAC par Audio Science Review (Amir)
Product typeDAC
DAC ChipAKM AK4493EQ
USB InterfaceXMOS XU208-128-TQ64-C10
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
Output1x Stereo RCA
AOPTexas Instruments OPA1678IDR
Frequency response20Hz - 20kHz ±0.12dB
SNR≥ -111dB
Dynamic range≥ -119dB
Linear error-90dBFS: 0.03dB
THD+N< 0.0003%
IMD CCIF0.0002%
IMD SMTPE< 0.0008%
Crosstalk-107dB
Supported sampling ratesOptical: PCM up to 24bit 96kHz
Coaxial: PCM up to 24bit 192kHz
USB : PCM up to 32bit 192kHz, DSD up to DSD128
Power supply12VDC 1A
Dimensions117 x 94 x 38mm
Weight420g
Housing materialAluminum
ColorBlack and silver
ColorSilver
Smooth
Smooth sound with good soundstage, not sounding digital and analytical like others dacs at this price.
Recomended :)
This review has been posted for MONOLITH LIQUID SPARK DAC AK4493 XMOS 32Bit 192kHz DSD128
The Monolith Liquid Spark DAC is a compact digital/analog converter developed by Alex Cavalli. It offers excellent audio quality and is especially...
