Pack Topping D30 Pro DAC CS43198 + Topping A30 Pro Headphone Amplifier NFCA + Topping TCX1 XLR Cable
This pack will allow you to enjoy an audio system composed of a Topping A30 Pro headphone amplifier and a Topping D30 Pro DAC, both of which are extremely high-performance, for rich, accurate and immersive listening.
By buying this product you get 56 loyalty points
Reference : 15174
568,00 €tax incl.
473,33 € tax excl.
Instead of 597,01 €
Pack content
Pack Topping
Pack Topping D30 Pro DAC CS43198 + A30 Pro Amplificateur Casque NFCA + TCX1 Câble XLR
This pack will allow you to enjoy an audio system composed of a Topping A30 Pro headphone amplifier and a Topping D30 Pro DAC, both of which are extremely high-performance, for rich, accurate and immersive listening. An XLR cable is also included, allowing you to connect the devices in a balanced way.
Topping A30 Pro
The Topping A30 Pro is a high quality headphone amplifier that will delight lovers of headphone listening. With two headphone outputs at different impedances and a three-level adjustable gain, it will work with all types of headphones. Its symmetrical amplification circuit allows it to offer excellent performance, ensuring great precision and richness of sound.
On the connector side, the A30 Pro offers balanced XLR or unbalanced RCA inputs. For its headphone outputs, the amplifier offers unbalanced 6.35mm jack, as well as 4-pin XLR and unbalanced 4.4mm jack. The A30 Pro also offers two pass-through outputs with unbalanced RCA or two mono 6.35mm jacks for the balanced output. These are not preamplifier outputs.
Learn more about Topping A30 Pro
Topping D30 Pro
Powerful and compact symmetrical DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198 chips. These enable it to support high sample rates up to 32bit 384kHz PCM and DSD256, while offering incredible performance in terms of distortion level, THD+N and dynamics.
Learn more about Topping D30 Pro
Topping TCX1
TCX1 cables from Topping are high quality XLR male/female cables. They incorporate 6N Copper and Silver plated 6N Copper conductors for perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable has a beautiful and robust black and red braided nylon sheath.
Learn more about Topping TCX1
Topping A30 Pro Specifications
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Outputs1x Single-ended Jack 6.35mm headphone output
1x Balanced Jack 4.4mm headphone output
1x Balanced XLR 4 poles headphone output
1x Single-ended stereo RCA (pass through)
2x Balanced mono Jack 6.35mm (pass-through)
THD0.00009% @ 1kHz
SINAD121dB
SNR128dB @ Mid gain, 4V In/Out
95dB @ Mid gain, 50mV Out, 600Ω
THD0.00009% @ 1kHz
Frequency response10Hz - 30kHz
Topping D30 Pro Specifications
Product typeDAC
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x Stereo RCA
DAC Chips4x Cirrus Logic CS43198
Sampling ratesUSB : PCM up to 32bit 384kHz, Native DSD up to DSD256, DSD DoP up to DSD128
Coaxial / Optical : PCM up to 24bit 192kHz, DSD64 (DoP)
THD+N @ A-WeightingRCA : < 0.0001% @ 1kHz
XLR : < 0.00009% @ 1kHz
THD @ No-Weighting 45kBwRCA : < 0.0004% @ 20Hz-20kHz
XLR : < 0.0004% @ 20Hz-20kHz
SNR @ A-WeightingRCA : 127dB @ 1kHz
XLR : 132dB @ 1kHz
Dynamic range @ A-WeightingRCA : 127dB @ 1kHz
XLR : 132dB @ 1kHz
Frequency responseRCA : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
XLR : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB)
Output voltageRCA : 2Vrms @ 0dBFS
XLR : 4Vrms @ 0dBFS
Noise @ A-WeightingRCA : < 0.9µVrms
XLR : < 1.1µVrms
CrosstalkRCA : -116dB @ 1kHz
XLR : -145dB @ 1kHz
Output impedanceRCA : 20Ω
XLR : 40Ω
Topping TCX1 Specifications
Product typeXLR Cable
Connectors1x 3 poles male XLR
1x 3 poles female XLR
Length25cm
Cable external diameterØ8mm
Conductors materialCopper
Silver plated Copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
External sheathBraided Nylon
ColorBlack and red
QuantitySold in pair (1 cable with red rings, 1 cable with black rings)
InputXLR
OutputJack 3.5mm
OutputJack 6.35mm
OutputJack 4.4mm
ClassN/A
Remote ControlYes
This pack will allow you to enjoy an audio system composed of a Topping A30 Pro headphone amplifier and a Topping D30 Pro DAC, both of which are...
