Schiit VALHALLA 2 Class A Tube Amplifier Zero Feedback
Valhalla 2 is a complete reinvention of the Valhalla, with improved performance, higher capacity, lower distortion and output impedance.
This class A tube amplifier is standard equipped with the best components on the market (Alps potentiometer, Dale resistors, Wima capacitors ...).
This will give you a warm and detailed sound as well as sustained bass.
While most OTL tube amps are really only designed for 300 ohm and 600 ohm headphones, Valhalla 2 allows you to use other types of headphones to reveal the best. Try it with an AKG or a Grado!
Characteristics :
P>
P>
P>
