Schiit VALHALLA Amplifier Tube Headphones Zero Feedback
By buying this product you get 35 loyalty points
Reference : 6415
359,00 €tax incl.
299,17 € tax excl.
Schiit VALHALLA Class A Amplifier with Tubes Zero Feedback
This class A tube amplifier is standard equipped with the best components on the market (Alps potentiometer, Dale resistors, Wima capacitors ...).
This will give you a warm and detailed sound as well as sustained bass.
Able to "Driver" effortlessly the most demanding headsets (600 ohms), this amplifier will quickly become the companion of elitist listening.
Features:/ P>
  • Supported impedance: 32-600 ohms
  • Gain: 8 (18 dB)
  • Frequency response: 10Hz-200KHz, -3dB
  • Max Output: 30V PP
  • THD: less than 0.5%, 20Hz-20KHz, at 1V
  • Topology: Class-A triode, zero feedback, single voltage gain stage
  • Tubes: 6N1P and 6N6P
  • Power Consumption: 40W
  • Dimensions: 230 x 180 x 90 mm
  • Weight: 3.5 kg
https://www.audiophonics.fr/images2/6415/6415_SCHIITVALHALLA_3.jpg
https://www.audiophonics.fr/images2/6415/6415_SCHIITVALHALLA_1.jpg
https://www.audiophonics.fr/images2/6415/6415_SCHIITVALHALLA_2.jpg
https://www.audiophonics.fr/images2/6415/6415_SCHIITVALHALLA_4.jpg
