SMSL P1 Balanced Headphone Amplifier 2x3W 32 Ohm Black
The SMSL P1 is a high-end headphone amplifier with symmetrical architecture. Its output circuitry based on discrete components allows it to achieve excellent performance with a distortion level of 0.00019%, a signal-to-noise ratio of 120dB or an output current 5 times higher than their previous headphone amplifiers.
By buying this product you get 79 loyalty points
Reference : 14187
799,00 €tax incl.
665,83 € tax excl.
SMSL P1
SMSL P1 Amplificateur Casque Symétrique 2x3W 32 Ohm Noir
xxx
High quality components
SMSL has taken care to select only high quality components in order to allow the P1 to develop excellent audio performance and a rich, dynamic and accurate sound reproduction.
The amplification circuit is thus based on 4 AOPs in a symmetrical architecture with feedback correction circuit. Digital volume control is handled by a PGA2311U.
The power supply includes a custom Norateluk low noise transformer offering an efficiency 1.3 times higher than a conventional transformer. 6 Siemens Epcos coupling capacitors, WIMA capacitors or low noise regulators allow filtering to deliver an electrical signal specific to the different circuits. In addition, the power supply circuit is physically separated from the other circuits to limit the impact of interference.
Connectivity
The SMSL P1 offers simple and efficient connectivity. The rear panel of the unit features 2 unbalanced RCA stereo inputs and 1 balanced XLR input. On the output side, the amplifier displays on the front panel a 4-pole balanced XLR output and an unbalanced 6.35mm jack output.
xxx
Aluminium housing & Remote control
All the circuits of the SMSL P1 are integrated in a magnificent black CNC machined and anodized Aluminium case. Sober, modern and robust, the amplifier will easily integrate into a HiFi system or on a desk. The P1 comes with a compact aluminium remote control for easy and remote control of the amplifier.
xxx
Product typeBalanced headphone amplifier
Inputs2x Single-ended stereo RCA
1x Balanced XLR
Outputs1x Single-ended Jack 6.35mm
1x Balanced 4 poles XLR
Output power (single-ended)1.5W @ 32Ω
1W @ 64Ω
600mW @ 150Ω
300mW @ 300Ω
150mW @ 600Ω
Output power (balanced)3W @ 32Ω
2W @ 64Ω
1.2W @ 150Ω
800mW @ 300Ω
500mW @ 600Ω
Frequency response1Hz - 200kHz (-3dB)
THD+NSingle-ended: 0.00028%
Balanced: 0.00019%
SNR (A-Weighted)Single-ended: 117dB
Balanced: 120dB
Consumption18W
Standby consumption0.5W
Case materialAluminium
Dimensions265 x 215 x 50mm
Weight4kg
Input
  • RCA
  • XLR
Output
  • Jack 6.35mm
  • XLR
Color
  • Black
Remote Control
  • Yes
The SMSL P1 is a high-end headphone amplifier with symmetrical architecture. Its output circuitry based on discrete components allows it to achieve...
