SMSL after sales service return product. New product, box slightly damaged.
Here is the brand new SMSL SAP-9, a headphone amplifier at symmetrical output which is the culmination of a long search of the brand's engineers. 2 amplification chips TPA6120A2 were used, so the amplification circuit separates the 2 right and left channels well.
In order to create a balanced circuit with zero noise and an extremely clean sound, the latter has a completely independent architecture and tracking. The volume control of this headphone amplifier will be done in the best digital way.
The SAP-9 SMSL offers you a connectors extended. In analog inputs, you will have the balanced stereo XLR port as well as the gold-plated stereo RCA port. In analog outputs you will have a 6.35mm jack headphone jack, a 2.5mm 4-pole balanced jack, as well as to complete the 4-pole balanced XLR headphone output her too.
Main Features :
- Amplification chip: 2x TPA6120A2 (Datasheet can be downloaded below)
- Signal to noise ratio: 110dB
- Balanced XLR input / output: Zero noise and its own
- Symmetric circuit architecture COMPLETE Independently Owned
- Digital Control of volume
Output characteristic not symmetrical (THD + N = 0.1%):
- 32 Ohm - 175mW
- 64 Ohm - 130mW
- 150 Ohm - 78mW
- 300 Ohm - 45mW
Symmetrical output characteristics (THD + N = 0.1%):
- 32 Ohm - 373mW
- 64 Ohm - 342mW
- 150 Ohm - 245mW
- 300 Ohm - 155mW
Connectors:
- RCA Stereo Plated Gold Input
- Balanced XLR stereo input
- Headphone Jack Jack 6.35mm
- Headphone output Jack 2.5mm 4-pole symmetrical
- Headphone output XLR 4-pole symmetrical
Dimensions / Weight / Power supply:
- Dimensions: 121x120x36mm
- Weight: 443g
- Power supply: 5V / 2A DC (AC power adapter included)
- Power Consumption: 7.2W
