SMSL SP400 Balanced Headphone Amplifier THX AAA-888 MQA
SMSL offers with its SP400 an excellent headphone amplifier, based on a solid internal design. It integrates a THX amplifier chip, known for its incredible performance, as well as balanced and unbalanced inputs and outputs.
By buying this product you get 58 loyalty points
Reference : 14913
585,00 €tax incl.
487,50 € tax excl.
SMSL SP400
SMSL SP400 Amplificateur Casque Symétrique THX AAA-888 MQA
Test By Audio Science Review
It is my pleasure to strongly recommend the Topping Pre90. If you needed to have another source beside your DAC to play in your system, you now have a wonderful way to accomplish that with zero impact on performance.
 test by the measurement forum Audio Science Review
THX Amplification chip
The SP400's amplification circuitry includes a high-performance THX AAA-888 chip. It is capable of developing a high power output to accompany the vast majority of headphones on the market, including the most demanding, while maintaining a very low level of harmonic distortion. This chip is, of course, accompanied by high quality and high precision components to enable the SP400 to unveil its full potential and a rich and accurate reproduction.
In addition, the SP400 supports playback of Master Authenticated Quality (MQA) files, which provides playback as close as possible to the original studio recording.
Balanced & Single-Ended
Versatile, the SP400 has both balanced and unbalanced inputs and outputs. The SP400 is equipped with both balanced and unbalanced inputs and outputs, so both unbalanced RCA and balanced XLR inputs are available. On the output side, the SP400 offers an unbalanced 6.35mm jack headphone output, a balanced XLR 4-pin headphone output and a balanced XLR Pre-Out output.
High precision volume control
The SP400's relay volume control allows for extremely precise adjustment of the sound level, while ensuring low noise. The volume control has 256 levels.
Custom power supply
The power supply circuit of the SP400 is not to be outdone, SMSL integrating 2 custom designed 24W high efficiency and low noise power supplies. These last ones allow to provide to all the audio circuits a clean electrical signal, essential to ensure a high quality sound reproduction.
Design
All of the SP400's components are integrated into a beautiful CNC machined aluminum housing. The design of the SP400 follows the design of the other devices in the range for visually consistent integration.
The front of the device is also adorned with a beautiful OLED screen, displaying all the useful information and allowing intuitive navigation.
Adjustable gain
In order to adapt to all types of helmets, the SP400 offers a 3-level gain control. Thus, it is possible to use either a high-sensitivity helmet or a high impedance model.
Product typeBalanced headphone amplifier
Amplification chipTHX AAA-888
Înputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Outputs1x Jack 6.35mm single-ended headphone output
1x XLR 4 poles balanced headphone output
1x XLR Balanced output (Pre-Out)
Power outputBalanced : 2x 12W @ 16Ω, 2x 6W @ 32Ω, 2x 880mW @ 300Ω, 2x 440mw @ 600Ω
Single-ended : 2x 6W @ 16Ω, 2x 3W @ 32Ω, 2x 440mW @ 300Ω, 2x 220mW @ 600Ω
SNR133dB (A-Weighted)
Output noise1.9µV (A-Weighted)
THD+N-123dB, 0.00007% (1kHz, 32Ω)
-117dB, 0.00013% (20Hz - 20kHz, 32Ω, -3dB)
THD< -125dB, 0.00006%
Input impedance47kΩ
Output impedanceApprox. 0Ω
Frequency response0.1Hz - 500kHz (-3dB)
general
Power supplyAC100-240V, 50-60Hz
Consumption< 40W
Standby consumption< 0.1W
Dimensions225 x 210 x 43mm
Weight1330g
Package1x SMSL SP400
1x Remote control
1x Power cable
SMSL SP400 Amplificateur Casque Symétrique THX AAA-888 MQA SMSL SP400 Amplificateur Casque Symétrique THX AAA-888 MQA
Input
  • RCA
  • XLR
Output
  • Jack 6.35mm
  • XLR
Color
  • Black
Class
  • Class D / T
Remote Control
  • Yes
2 reviews
smsl sp400
Ecouter avec le audio technica Ath adx5000.
Tout est clair ,précis ,limpide,aérien,bref une petite merveille.
ATTENTION au cable de sorti du dac ou autre préamplificateur,ne rechigner pas sur un très bon cable ,(pour ma part)la troisième tentative a était la bonne sinon pas d'effet magique.(je ne cite pas la marque du cable car les nuances de certain ne conviennent pas a d'autres)
Petite télécommande ,en revanche bien pratique et réactive.
Très satisfait de cette achat rapport qualité prix très intéressant.
Merci Audiophonics
This review has been posted for SMSL SP400 Balanced Headphone Amplifier THX AAA-888 MQA
Trés bon produit
Combiné au M400 cet ampli est un peu moins puissant que le SP200 mais l’équilibre des canaux est parfait, l’écoute est très propre avec des basses puissantes mais pas trop.
SMSL offers with its SP400 an excellent headphone amplifier, based on a solid internal design. It integrates a THX amplifier chip, known for its...
