Headphone Amplifier Audiophile Analog
The SMSL VMV VA2 is a high quality headphone amplifier and ideal companion for the Magic converter of the same brand. Capable, despite its small size, of driving the most demanding headsets on the market, it will be as comfortable behind a DAC as it is connected directly to an analog source. It has two 6.35mm headphone outputs: one for high impedance headphones and the other for low impedance headphones. This allows it to be used universally, whether with in-ear earphones or 600Ω headsets.
" So overall, a competent design from SMSL here and I can recommend it. "
Product type | Headphone amplifier |
Input | 1x Stereo RCA |
Outputs | 2x Jack 6.35mm |
Frequency response | 20Hz - 20kHz |
THD+N | < 0.0003% @ 1kHz, <0.0008% @ 20Hz-20kHz |
SNR | > 122dB |
Crosstalk | < 95dB-1kHz, <-75db 20hz-20khz="" td=""> |
High impedance output power | > 120mW @ 600Ω, > 250mW @ 300Ω, > 580mW @ 100Ω, > 330mW @ 32Ω |
Low impedance output power | > 120mW @ 100Ω, > 75mW @ 32Ω |
Case material | CNC machined Aluminium |
Color | Silver |
Power supply | 12VDC 1A via Jack DC 5.5/2.5mm (power adapter included) |
Dimensions | 120 x 95 x 22mm |
Weight | 0.5kg |
