TOPPING L30 Headphone Amplifier / Preamplifier NFCA Black
The Topping L30 is a headphone amplifier with preamplifier function that is compact, affordable and, above all, extremely powerful! It benefits from excellent measurements, allowing it to deliver a sound reproduction of incredible precision, richness and dynamics.
Reference : 14704
149,00 €tax incl.
124,17 € tax excl.
Topping L30
Headphone Amplifier / Preamplifier Black
Topping L30 Amplificateur Casque Noir
Ultra high performance NFCA modules
The L30 uses the same NFCA (Nested Feedback Composite Amplifier) modules as the Topping A90 flagship. The hybrid voltage/current feedback architecture combined with UHGF (Ultra High Gain Feedback) technology provides excellent AC and DC performance. The unit's high output level allows it to easily accompany low impedance headphones. The L30's ultra-low noise of 0.3µV gives it a considerable lead over the competition, as does its extremely high dynamic range of 141dB. It is therefore capable of delivering vivid sound reproduction with unrivalled clarity. During measurements, the high limits of the Audio Precision APX555B analyzer have even been reached!
Suitable for all types of headphones
With an output level of 26Vp-p, a power of 2x 3500mW and an output impedance of less than 0.1ohm, the L30 will have no problem fitting to all types of headphones. The L30 will work equally well with high impedance headphones that require a high power input, as well as with in-ear earphones with very high sensitivity.
Adjustable gain
In order to make the L30 compatible with the widest range of listening devices, the headphone amplifier features a gain selector switch. Three parameters are available: -9.9dB, 0dB and 9.5dB.
Preamplifier function
The NFCA modules of the L30 are not only capable of accompanying most headphones and earphones on the market, but also function as a preamplifier with incredible performance. In preamplifier mode, the output impedance is only 20Ω and therefore suitable for most devices.
1Output mode switch
2Gain switch
3Power indicator
4Jack 6.35mm headphone output
5Volume knob
6Right channel analog RCA input
7Left channel analog RCA input
8Right channel analog RCA output
9Left channel analog RCA output
10Power input
Topping L30 review by Audio Science Review
The race toward perfection and beyond continues in headphone amplifiers at incredibly low prices. The L30 is the latest offering, firmly grabbing the top of the class and holding on to it. Its functionality is excellent and price is very reasonable. "
Test du Topping L30 par Audio Science Review
InputsStereo RCA
Outputs1x Jack 6.35mm headphone output
1x Stereo RCA Pre-Out
Gain selection-9.9dB
0dB
+9.5dB
Headphone amplifier specifications
THD+N @ 1kHz, A-Weighting< 0.00007% @ Output = 500mW, 32Ω
< 0.00006% @ Output = 80mW, 300Ω
THD+N @ 20Hz-20kHz, 90kBW< 0.0001% @ Output = 500mW, 32Ω
< 0.00009% @ Output = 80mW, 300Ω
Dynamic range (DNR) @ 1kHz, A-Weighting141dB
SNR @ Max output level, 1kHz, A-Weighting141dB
Frequency response20Hz - 40kHz (±0.05dB)
Measured noise level @ A-Weighting< 0.7µVrms @ G=L
< 0.7µVrms @ G=M
< 0.9µVrms @ G=H
Actual noise level @ A-Weighting< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 0.7µVrms @ G=H
Output level26Vpp @ G=L
26Vpp @ G=M
26Vpp @ G=H
Channel crosstalk @ 1kHz-91dB
IMD CCIF @ 18kHz+19kHz-116dB
IMD SMPTE @ 60Hz+7kHz-110dB @ SMPTE4:1
-115dB @ SMPTE1:1
Input sensitivity25Vrms @ G=L
9Vrms @ G=M
3Vrms @ G=H
Output impedance< 0.1Ω
Max power2x 3500mW @ 16Ω THD+N < 0.1%
2x 2300mW @ 32Ω THD+N < 0.1%
2x 280mW @ 300Ω THD+N < 0.1%
Load impedance> 8Ω
Preamplifier specifications
THD+N @ 1kHz, A-Weighting< 0.00006%
THD+N @ 20Hz-20kHz, 90kBW< 0.00009%
< 0.7µVrms @ G=M
< 0.9µVrms @ G=H
Measured actual noise @ A-Weighting< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 0.7µVrms @ G=H
26Vpp @ G=M
26Vpp @ G=H
-115dB @ SMPTE1:1
9Vrms @ G=M
3Vrms @ G=H
Output impedance20Ω
Supply voltage15VAC (power supply included)
Dimensions10 x 13.4 x 3.2cm
Housing materialAluminum
Package1x Topping L30
1x Power supply
1x Jack 6.35mm to Jack 3.5mm adapter
RMS level
THD
FFT Spectrum
THD+N vs Measured Level
Input
  • RCA
Output
  • Jack 6.35mm
  • RCA
Color
  • Black
Class
  • N/A
Remote Control
  • No
5 reviews
Excellent
Service audiophonics impeccable comme d'habitude.
Ampli parfaitement neutre et transparent.
Très grande précision alliée à une grande douceur.
Le sélecteur de gain est indispensable je trouve , j'avais systématiquement sur mes autres amplis un problème pour régler le volume avec mon Sennheiser Momentum ( trop de gain).
Tout cela pour un prix mini.
This review has been posted for TOPPING L30 Headphone Amplifier / Preamplifier NFCA Black
Jiri Sobas
First impressions are very positive. Listening to Beyerdynamic headphones is really great. Use as a preamplifier for a power amplifier and speakers is also very good. I recommend!
Parfait
Produit répondant parfaitement à mes besoins, reçu plus rapidement que prévu.
Le petit géant
Le petit géant, je l'ai toujours sur l'ampli JDS Atom. Les spécifications que vous connaissez déjà sont toutes les deux très bonnes. Mais le son du L30 est plus riche en timbre et plus rapide en résolution! 5 étoiles !
Absolute beast!
Awesome headamp that drives my AKG K701 without any issues whatsoever. Solidly built. Can only recommend :-)
The Topping L30 is a headphone amplifier with preamplifier function that is compact, affordable and, above all, extremely powerful! It benefits...
