TOPPING L30 II NFCA Headphone Amplifier Preamplifier Silver
Topping unveils its L30 II, evolution of the very good L30 headphone amplifier and preamplifier. This new version is based on the architecture of the first model, while bringing many improvements to optimize the performance of the device and its sound reproduction.
Reference : 16716
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 16-04-2025.
Topping L30 II
Topping L30 II Amplificateur casque NFCA Préamplificateur Argent
Differences between L30 II and L30
L30 II
L30
Amplifier
Optimized NFCA module
NFCA
THD+N
< 0.00006%
< 0.00007%
Dynamic range
144dB
141dB
Output power @ 300 Ohm
2x 560mW
2x 280mW
Gain
-14dB / 0dB / 16.5dB
-9.9dB / 0dB / 9.5dB
Output voltage
37Vpp
26Vpp
Improved NFCA
The Topping L30 II uses a revised NFCA (Nested Feedback Composite Amplifier) amplifier module. This one allows notably to double the output power available under 300Ω, compared to the L30. An output power offering the possibility to the L30 II to accompany the vast majority of headphones on the market, including the most demanding models with a high impedance. The new circuit also offers an ultra-low noise level measured at 0.3µV, a dynamic page of 144dB as well as a THD+N of 0.00006%.
Gain setting
In order to allow the L30 II to accompany both high-impedance headphones and very sensitive in-ear monitors, the amplifier offers a three-level gain control: -14dB, 0dB and 16.5dB.
1Output selector
2Gain selector
3Power indicator
4Jack 6.35mm headphone output
5Volume button
6Right channel RCA input
7Left channel RCA input
8Right channel RCA output
9Left channel RCA output
10Power connector
Product typeHeadphone amplifier and preamplifier
Amplification moduleNFCA
Input1x Stereo RCA
Outputs1x Stereo RCA
1x Jack 6.35mm headphone outout
Headphone amplifier measurements
THD+N @ 1kHz, A-Weighting< 0.00006% @ 500mW, 32Ω
< 0.00005% @ 80mW, 300Ω
THD @ 90kBw, 20Hz-20kHz< 0.00008% @ 500mW, 32Ω
< 0.00007% @ 80mW, 300Ω
SNR @ Max Out, 1kHz, A-Weighting144dB
Dynamic range @ 1kHz, A-Weighting144dB
Frequency response20Hz-40kHz (±0.05dB)
Output level14Vpp @ G=L
31Vpp @ G=M
37Vpp @ G=H
Noise level< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 1.4µVrms @ G=H
Crosstalk @ 1kHz-92dB
Input sensitivity25Vrms @ G=L
11.2Vrms @ G=M
2.0Vrms @ G=H
Gain-14dB @ G=L
0dB @ G=M
16.5dB @ G=H
Output impedance< 0.1Ω
Output power2x3500mW @ 16Ω, THD+N < 0.1%
2x2700mW @ 32Ω, THD+N < 0.1%
2x2000mW @ 64Ω, THD+N < 0.1%
2x560mW @ 300Ω, THD+N < 0.1%
Load impedance> 8Ω
Preamplifier measurements
THD @ 90kBw, 20Hz-20kHz< 0.00007%
Dynamic range@ 1kHz, A-Weighting144dB
31Vpp @ G=M
37Vpp @ G=H
< 0.3µVrms @ G=M
< 1.4µVrms @ G=H
11.2Vrms @ G=M
2.0Vrms @ G=H
Gain-14dB @ G=L
0dB @ G=M
16.5dB @ G=H
Output impedance20Ω
Dimensions100 x 135 x 32mm
ColorSilver
Package1x Topping L30 II
1x Power adapter
1x Male Jack 6.35mm to Female Jack 3.5mm adapter
OutputJack 6.35mm
ColorSilver
Parfait sauf...
Arrivé rapidement et très bien emballé. Fonctionne parfaitement, et facile d'utilisation. Je suis malheureusement déçu par le bloc d'alimentation, qui fait 9cm de long par 5cm de large par 6cm de haut... Énorme et consomme aussi énormément pour une sortie 15v 1a, il consomme 6w au repos et je n'ai pas pu tester sa conso en charge. Pour comparaison mon chargeur téléphone consomme moins d'1w au repos et 3w en charge en sortie 15v 3a...
En fonctionnement l'ampli chauffe légèrement (normal pour un classeA) mais même après des heures d'utilisation, il est juste tiède au touché.
Et enfin le son ! Extrêmement propre, hyper réactif, puissant, pourrais sûrement détruire mon casque et pousse facilement aux maximum mes haut-parleurs, sans distorsion !
This review has been posted for TOPPING L30 II NFCA Headphone Amplifier Preamplifier Silver
Topping unveils its L30 II, evolution of the very good L30 headphone amplifier and preamplifier. This new version is based on the architecture of...
