TOPPING TP31 DAC / Headphone Amplifier Tripath TA2024 24 / 192kHz 2x 15W
Topping TP31 DAC/Amplificateur casque Tripath TA2024 24/192kHz
4.0 / 5
Reference : 8930
94,90 €tax incl.
79,08 € tax excl.
The TP31 is a small device full of resources. At the same time, amplifier, DAC, and headphone amplifier, the TP31 is made up of high quality audiophile components.
Based on a Class-T Tripath architecture with a TA2024 chip, this T-amp delights you with its precise and dynamic sound, despite its low maximum power of about 2x15W.
The digital analog conversion is managed by a Cirrus Logic CS8416 capable of handling sampling frequencies up to 192 kHz with low jitter.
Features:/ Strong>
  • Amplifier Class T: Tripath TA2024B
  • Output power max. :
  • 16.3W (RL = 4Ω, THD + N = 10%)
  • 9.7W (RL = 8Ω, THD + N = 10%)
  • THD + N: 0.003%
  • THD + N (@ 1kHz): 0.012%
  • Frequency Response: 20-20kHz ± 0.6dB
  • Sensitivity: 420mVrms
  • Gain (@ 1kHz): 27dB
  • DAC Cirrus Logic CS8416
Headphone Amplifier:
  • Impedance: 16-300Ω
  • Output power max: 140mW (RL = 32Ω, THD + N = 1%)
  • THD + N: 0.002% (RL = 32Ω, Pout = 45mW)
  • THD + N (@ 1kHz) 0.03%
  • Sensitivity: 1.1Vrms
  • Gain (@ 1kHz): 6dB
Components:
  • TOKO
  • ALPS
  • Resistance KOA
  • Panasonic relays
  • Capacitors Elna, ERO, EPCOS and Nichicom FW
  • AOP Burr-Brown OPA2134
  • Aluminum chassis CNC
  • HP Protection
  • Headphone Jack Jack 3.5mm x1
  • Power supply: 12 VDC (adapter supplied)
  • Dimensions: 20 x 11.5 x 5 cm
  • Weight: 690g
https://www.audiophonics.fr/img/p/7/3/9/0/7390.jpg
https://www.audiophonics.fr/img/p/7/3/8/5/7385.jpg
https://www.audiophonics.fr/img/p/7/3/8/4/7384.jpg
2 reviews
Que du bon !
Comment le dire , ben il faut écouter !
Test en cours sur Highland 3203 (rodées) avec divers genres de musiques, non destiné à ces enceintes.
Cet ampli est cash, il traduit votre source native directe, sans réglage possible, donc pas de tricheries avec les graves ou les aigüs à régler et autres bidouilles. Si vous avez de la daube donc vous écouterez de la daube.
Coté musique, je vais faire simple
Les versions concert : bien, mais un peu compliqué pour lui, tout de même, je l'ai trouvé un peu fouilli.
Les versions album : très bon, en général, et ce quelque soit les genres.
En style de musique, le blues ou des versions acoustiques, ce qui pourrait être finalement son domaine de prédilection, avec une telle précision, ça déchire !
... et lorsque l'on remet les choses dans leur contexte, je me dis que pour le prix , c'est génial.
This review has been posted for TOPPING TP31 DAC / Headphone Amplifier Tripath TA2024 24 / 192kHz 2x 15W
Très bon ampli à tout faire
Ce minuscule ampli procure une écoute lumineuse, raffinée, très vivante sur des Eltax Monitor III, en écoute de proximité. Beaucoup de détail, pas d'agressivité.
Ecouté rapidement sur mes "grosses" enceintes (2x Focal 5W + 1 Raven R1), on conserve le côté vivant et souple, les instruments sont bien détourés, les attaques sont franches, mais le grave est clairement plus court que d'habitude. Une meilleure alim pourrait compenser ce problème ?
La sortie casque et le DAC sont d'un niveau plus que correct, mais mon DAC externe (Musiland Monitor 01 US) fait mieux. En comparaison le DAC du topping sonne un peu mat et voilé. Mais le tout reste quand même d'un très bon niveau (d'ailleurs je conserve le casque branché sur le topping pour des raisons pratiques).
La qualité de fabrication est très bonne.
Bref, à ce prix, rien à redire, c'est du très bon matériel ! Un ampli qui donne envie d'aller plus loin avec les Tripath pour mon système principal.
