XDUOO MT-604 Headphone Amplifier 4x 6J1 Tubes Transistors Class A Balanced
The MT-604 from xDuoo is a headphone amplifier based on the use of 4 6J1 tubes to deliver a soft and warm sound. These tubes are associated with transistors for the Class A buffer, allowing to have a comfortable output power to accompany a great majority of the headphones of the market.
Reference : 15353
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 16-04-2025.
xDuoo MT-604
xDuoo MT-604 Amplificateur Casque à Tubes 4x 6J1 Transistors Class A Symétrique
The MT-604 from xDuoo is a headphone amplifier based on the use of 4 6J1 tubes to deliver a soft and warm sound. These tubes are associated with transistors for the Class A buffer, allowing to have a comfortable output power to accompany a great majority of the headphones of the market. This design allows to take advantage of both technologies: the musicality of the tubes and the great dynamics and precision of the transistors, while developing a power of 2000mW. The power supply stage is filtered with Rubycon filtering capacitors.
The amplifier also benefits from a balanced connection. We find stereo XLR and 4.4mm jack on the input and 4 pole XLR and 4.4mm jack on the output.
The MT-604 also offers an independent volume control for each channel. This function allows a better separation of the channels.
Product typeTube headphone amplifier
Inputs1x Balanced stereo XLR
1x Balanced Jack 4.4mm
Outputs1x Balanced 4 poles XLR headphone output
1x Balanced Jack 4.4mm headphone output
Output power2000mW @ 1kHz, 32Ω
Dynamic range85dBA @ 32Ω
Frequency response10Hz~60kHz (±0.5dB)
Recommended headphone impedance16Ω ~ 600Ω
Gain+15dB
SNR115dB
THD+N≤ 0.01% @ 1kHz, 32Ω
Dimensions170x100x60mm
Weight550g
InputJack 4.4mm
InputXLR
OutputJack 4.4mm
ColorGray
ClassTube amp
ClassClass A / AB
Cheap and cheerful tube amp
I’m surprised by the performance of this hybrid tube amp. Simple and powerful enough to drive my HE1000SE headphones. Would certainly recommend for any newbie tube enthusiasts
This review has been posted for XDUOO MT-604 Headphone Amplifier 4x 6J1 Tubes Transistors Class A Balanced
The MT-604 from xDuoo is a headphone amplifier based on the use of 4 6J1 tubes to deliver a soft and warm sound. These tubes are associated with...
