XDUOO TA-20 PLUS XLR Balanced Class A Headphone Amplifier with Tubes 1x5Z4P 2x12AU7
An upgrade of the TA-20, the TA20 PLUS from xDuoo features a number of improvements. This fully symmetrical Class A tube headphone amplifier now boasts a 5Z4P correction tube in addition to its two 12AU7 amplification tubes, for an even warmer, more rounded sound. It now also incorporates a VU meter on the front panel, and an aesthetic design that's more stretched across the width, even though it remains very compact.
By buying this product you get 52 loyalty points
Reference : 18314
529,00 €tax incl.
440,83 € tax excl.
Shipping date: 08-05-2025.
XDUOO TA-20 PLUS
XDUOO TA-20 PLUS Amplificateur Casque Symétrique XLR à Tubes 1x5Z4P 2x12AU7 Class A
An upgrade of the TA-20, the TA-20 PLUS from xDuoo features a number of improvements. This fully symmetrical Class A tube headphone amplifier now boasts a 5Z4P correction tube in addition to its two 12AU7 amplification tubes, for an even warmer, more rounded sound. It now also incorporates a VU meter on the front panel, and an aesthetic design that's more stretched across the width, even though it remains very compact. It also adopts Class A transistors, enabling it to develop considerable power and drive headphones with impedances ranging from 16Ω to 600Ω. Its comprehensive connectivity makes it easy to integrate into any Hi-FI installation.
A fully balanced circuit
xDuoo's TA-20 PLUS features a fully balanced circuit between the XLR inputs and the balanced headphone outputs. This enables this headphone amplifier to achieve excellent performance, with a crosstalk of 95dB, an SNR of 113dB and a THD+N of just 0.05%.
Significant output power
On its balanced 4.4mm jack and 4-pin XLR headphone outputs, the TA-20 PLUS is capable of delivering an output power of 2600mW for 32Ω of load. Its 6.35mm jack headphone output is rated at 2000mW for 32Ω of load. This amplifier is therefore capable of driving headphones from 16Ω to 600Ω, and is compatible with a large majority of headphones on the market.
High-end components
The TA-20 PLUS amplifier circuit incorporates two high-performance 12AU7 matched tubes, plus a 5ZP4 tube for enhanced sound reproduction. Class A transistors are also used to boost output power. Customized capacitors are incorporated in the output stage, while ELNA SILMIC (II) capacitors are used at the input. It also incorporates Japanese Panasonic filter capacitors.
A compact, aesthetically pleasing headphone amplifier
The TA-20 PLUS adopts a compact format, taking up less space than an A4 sheet, so it's easy to place. Its front panel features a VU meter and a red rotary knob, contrasting with its silver aluminum case.
Complete connectivity
1XLR 4-pin balanced headphone output
2Balanced 4.4mm jack headphone output
36.35mm jack unbalanced headphone output
4Stereo RCA line output
52x Stereo RCA line input
6Balanced XLR input
7Balanced 4.4mm jack input
8Mains voltage selector switch
9IEC power socket / Fuse / Power switch
Product typeClass A tube headphone amplifier
Tubes2x 12AU7
1x 5ZP4
Inputs1x Balanced XLR input
1x Balanced line input 4.4mm jack
Outputs1x 4.4mm balanced headphone output
1x XLR 4-pin balanced headphone output
1x 6.35mm unbalanced headphone output
1x RCA line output
Gain+18dB
Suitable headphone impedance16Ω-600Ω
BALANCED HEADPHONE OUTPUTS: 4.4MM JACK AND XLR 4 PINS
Output power2600mW @32Ω
Frequency response10Hz-80kHz
Crosstalk95dB
SNR113dB
THD+N0.05%
UNBALANCED HEADPHONE OUTPUT: 6.35MM JACK
Output power2000mW @32Ω
Crosstalk74dB
SNR113dB
THD+N0.05%
Power supply110V/220V (Voltage selector on rear panel)
ColorSilver
Dimensions (LxHxP)26 x 17.7 x 15.3mm
Weight4.3kg
Package1x XDUOO TA-20 PLUS tube headphone amplifier
1x Power cable
Input
  • Jack 4.4mm
  • RCA
  • XLR
Output
  • Jack 4.4mm
  • Jack 6.35mm
  • RCA
  • XLR
Color
  • Silver
Class
  • Class A / AB
Remote Control
  • No
An excellent amplifier in its price range
A very good amplifier that deserves every last penny spent, the sound is unexpectedly good and after replacing the 12AU7 tubes with PSVANE 12AU7-S S Series the sound became even better even though the new tubes didn't have time to burn in. And as a bonus it is also very beautiful. I've been listening to it for several days and I can't get enough of it. I recommend it 100%
This review has been posted for XDUOO TA-20 PLUS XLR Balanced Class A Headphone Amplifier with Tubes 1x5Z4P 2x12AU7
An upgrade of the TA-20, the TA20 PLUS from xDuoo features a number of improvements. This fully symmetrical Class A tube...
