XDUOO TA-20 Tube Headphone Balanced Amplifier class A Hybrid
The xDuoo TA-20 is an excellent amplifier for tube headphones, ensuring great timbre accuracy. It will be able to driver many high-impedance audiophile headphones.
By buying this product you get 39 loyalty points
Reference : 12269
399,00 €tax incl.
332,50 € tax excl.
Last items in stock !
Shipping date: 26-03-2025.
xDuoo TA20
Hybrid Tube Headphone Amplifier xDuoo TA20 Amplificateur Casque à Tube
This amplifier is a more upmarket evolution of the small xDuoo TA02 headphone amplifier. Equipped with two classic 12Au7 triode tubes recognized for the quality of their timbre, this class A transistor and tube helmet amplifier is capable of controlling a wide range of high-impedance (600Ohm) audiophile models with its symmetrical 4-pole balanced connector " Sennheiser ". it can bring sound tube to many audiophile Hifi helmets like AKG, Beyerdynamic, Sennheiser, Audeze, Audio Technica, Hifiman, Meze Audio.
Quality components
Integrating metallized polyester capacitors and Elna Silmic, quality load resistors, the xDuoo TA20 produces a melodic sound for long hours of musical enjoyment without auditory fatigue. In order to improve the sound opening and the timbre it is possible to change the tubes by more upscale models still paired like: PSVANE 12AU7-TIII
Compact and simplee of use
The xDuoo TA20 has a multifunctional volume button to choose from the 3 line inputs (2 RCA and a symmetrical XLR input) that can be identified on the front panel. With an area equal to a sheet of A5 paper, the xDuoo TA 20 takes up little space on a desk and will therefore be the ideal companion for desktop Hifi systems and small spaces of high quality.
Tube AmplifierFor symmetrical headphones
tubing12AU 7 X2
Integrated linear power supply230
Input selection and volumeWith multifunction button
screenIn front
Chassis MaterialCNC Machined Aluminum
Bandwidth10Hz to 100kHz +/- 1dB
Signal Noise Ratio115dB
Gain+ 18dB
Distortion by harmonic at 1kHz over 32Ω0.01%
Output power
Output power on Jack 6.352000mW on 32Ω
Output power on XLR Balanced 4 pins2000mW on 32Ω
Line inputs RCA and XLR
RCA inputsX2 line
Balanced input XLR balanced stereo X1
Headphone and line outputs
Stereo balanced 4-pin stereo headphone output on XLR balanced SennheiserFrom 8 to 600Ω
Stereo Headphone Jack 6.3mmGold Plated
Stereo Line Out
Miscellaneous
FoodInternal linear power supply AC100V 230V on IEC connector (cable sold separately)
Dimensions32 x 12 x 105mm
Weight1.55kg
xDuoo TA10
InputXLR
ClassClass A / AB
ClassTube amp
4 reviews
Très apprécié
Suite à mon 1er avis, les 12au7wa TAD sont meilleurs, je suis resté dessus.
J'ai beaucoup utilisé le HE-6 dessus, n'écoutant pas à des niveaux sonores très élevés.
Essai d'un HD800s c'est fantastique. Aucun autre ampli chez moi n'arrive à le faire s'exprimer comme ce xDuoo! ce casque est capable du meilleur comme du pire selon l'ampli.
This review has been posted for XDUOO TA-20 Tube Headphone Balanced Amplifier class A Hybrid
Très content
Belle surprise pour cet ampli qui m'apporte la chaleur dont je manquais avec le RME ADI-2-DAC seul. Je l'écoute avec un Focal Clear.
J'ai changé les tubes pour des Raytheon Black Plate en NOS (je n'ai pas trop essayé les tubes d'origine) et je suis très ravi :
- la spacialisation est vraiment bien, je redécouvre des instruments et leur "place" sur la scène,
- les basses sont tout en subtilité,
- les mediums bien présents.
C'est simple on a l'impression que le chanteur est à côté de nous avec le Groupe derrière, ça donne des frissons.
Merci à Audiophonics pour la rapidité de la livraison.
 (3)
très satisfait
J'ai eu beaucoup d'amplis casques. Je trouve le TA-20 vraiment très bon à l'écoute. La qualité principale est une grande douceur, mais pas au détriment de la définition ou de la sensation de puissance. Je le situe parmi mes amplis avec le meilleur niveau de détail, et la spatialisation est large.
Il semble mieux rendre en XLR symétrique, liaison au dac et sortie casque aussi, utilisant à mon avis la double triode de chaque tube 12au7 de préampli, et il y a un peu plus de puissance ressentie qu'en asymétrique contrairement aux chiffres sur le papier (?). J'ai un Hifiman HE-6 réputé gourmand qui fonctionne très bien avec. Ceux qui veulent des niveaux sonores très élevés sur ce casque devront rechercher des modèles d'amplis très puissants, mais à des niveaux bien confortables je ne ressens pas de manque avec le HE-6 (entre 65 et 75 sur 95 de volume). En particulier le grave est bien ferme et descend aux infras sans souci.
Les tubes d'origine ne sont pas ridicules, avec une spatialisation bien large. J'ai mis des PSVane qui sont plus fins dans le médium aigu, avec une spatialisation un peu moins impressionnante. Malgré le fait que ce soit un hybride, le changement de tubes s'entend.
J'ai bien aimé le très sympathique TA-10 toutefois un peu inférieur à mes meilleurs amplis. Le TA-20 est nettement supérieur, surtout en puissance, pour sa finesse, le niveau élevé de détail restitué.
 (3)
Very Good
Very good amplifier. Im using this with hifiman edition xx
The xDuoo TA-20 is an excellent amplifier for tube headphones, ensuring great timbre accuracy. It will be able to driver many high-impedance...
