XDUOO TA-26 Tube Headphone Amplifier 6N8P 6N5P
The TA-26 from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P tube for the preamplification stage and a 6N5P tube for its buffer.
By buying this product you get 27 loyalty points
Reference : 15508
275,00 €tax incl.
229,17 € tax excl.
This product has been replaced by the new version, the XDUOO TA-26S Balanced Headphone Amplifier / Tube Preamplifier 6N8P 6N5P.
xDuoo TA-26
xDuoo TA-26 Amplificateur Casque à Tubes 6N8P 6N5P
The TA-26 from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P tube for the preamplification stage and a 6N5P tube for its buffer. The input is on RCA connectors and the headphone output on 6.35mm jack. The TA-26 also has a pre-out RCA output to accompany an external amplifier or active speakers. Both outputs also benefit from the volume control of the device. Finally, all the components are integrated in a sturdy grey aluminum alloy case.
TubesPreamplifier : 6N8P
Buffer : 6N5P
Input1x Stereo RCA
Outputs1x Jack 6.35mm headphone output
1x Stereo RCA
Output power500mw @ 600/300Ω
Frequency response10Hz-30kHz (±0.5dB)
Gain+16dB
SNR110dB
THD+N≤ 0.1% (1kHz)
Recommended headphone impedance60-600Ω
Supply voltage220-240VAC (Power cable included)
Dimensions250 x 110 x 160cm
Weight3.9kg
ColorGray
OutputJack 6.35mm
ColorGray
ClassTube amp
4 reviews
Great tube amp for a very reasonable price with minor quirks
Ordered this thing from Germany, it arrived well packaged and without any issues. I will order from Audiophonics again if I ever need something. The prices are more than competetive and the service was nice and answered all my questions about the product.
The amp itself performs very nicely, but keep in mind that some USB ports could carry over some interference issues to your DAC and then to the AMP. Via USB I had some weird electrical buzzing, an optical cable fixed all those issues, so keep that in mind. This is not really an issue of this amp but more an issue that could happen with any computer and an AMP that is sensitive to picking these things up (this includes stuff from your phone too).
About the amp itself. Music sounds fuller with it, I am pairing it with the 650's from Sennheiser and it's pleasant. The transformer of the TA-26 can hum a little, mine does it but it's not noticeable when listening to music, but that's to be expected with a transformer like this (might be fixable so it's completely silent). The tubes are completely silent when not listening to anything, no humming, buzzing or microphonics in my case, so that's very nice.
This review has been posted for XDUOO TA-26 Tube Headphone Amplifier 6N8P 6N5P
Great product and great service
It’s my first tube and I am super happy with my purchase. Sounds sweet and a lot more fun than my solid state amp.
Other than that, I can only recommend this shop. Fast delivery to Germany and great after sales support.
Sans compromis / Du Tout Lampes / De la chaleur / Du soyeux
Du 'Tout tubes' de qualité sans dépenser une fortune ? oui ça existe ! Même les adeptes forcenés de l'hybride ne pourraient renier cette 'Jekyll' expérience. Je recommande l'utilisation de ce 'Tout Lampes' en pré-ampli de salon au sein d'une chaîne numérique ; bien qu'en ampli casque l'expérience demeure magnifiquement concluante (à relatif volume moyen (pas pour les ultra sensibles)). En conseil je me permettrais de préciser qu'il faut travailler un peu sur les volumes injectés tout au long de la chaîne (de la source DAC, Pré-ampli, Ampli) afin de profiter soudainement de l'apport chaleureux de ces lampes !
Le tube imposant de puissance est soyeux autoritaire (en attente de recevoir de nouveaux tubes à tester...) et accentue une orientation V shape (basses et aiguës un peu en avant sans toutefois être piquants).
La lampe pré-ampli d'origine même si elle génère des nuances 'tubesques' colorées, gagne à être changée (récemment mis une Electro Harmonix Gold, l'injection gagne en médium sans masquer l'amplitude colorée du spectre).
Conclusion, avec des manipulations je reste bluffé par l'apport soyeux que cet ampli est capable d'insuffler au final (rien de comparable avec le tout numérique), certes vous faudra t'il jongler avec les volumes des étages montés.. et soudainement vous atteindrez un nirvana pour sûr, non moins mélomane. Garanti !
Magnifique
J'ai acheté cet amplificateur à l'aveugle, sans regarder aucune review (faut dire il vient de sortir, aucun test officiel n'existe encore) et je suis agréablement surpris.
La première chose qui surprend, c'est la taille et le poids, il pèse bien ses 3kilos, et trône fièrement sur mon bureau.
Cela faisait longtemps que je n'avais pas eu de vrai ampli tube (j'ai un XA-10 et un TA-10) et ça m'avait manqué. C'est une claque. Le son est chaud, rond, puissant, les basses sont amples et frappent fort. Les aigus agréables et pas trop agressifs comme on peut s'y attendre. C'est vraiment un bonheur à écouter avec un bon casque de studio (dt 1770 et m50x pour ma part). N'étant pas un immense audiophile, je ne vous parlerai pas plus en détails du son, c'est avant tout une machine à émotions, il faut l'essayer par vous même.
Le bouton power en façade est parfait, surtout quand on a l'habitude du bouton en plastique caché derrière le boitier.
Le bouton volume est assez sensible (à mi-volume sur une sortie ligne numérique vous n'avez plus de tympans, sur une platine vinyle ça va).
La sortie casque a une petite interférence qui correspond je pense à l'alimentation. On entend une légère masse, qui ne dépend pas de l'entrée, et qui se fait oublier une fois le volume à 10%.
En bref pour le prix c'est une affaire, je pense qu'il est équivalent à un darkvoice, mais en plus joli et plus original.
The TA-26 from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P...
