The xDuoo XA-02 is a high-performance DAC and headphone amplifier based on audiophile components. It features an ESS ES9039Q2M DAC chip that supports sampling rates up to PCM 32bit 384kHz, native DSD up to DSD256 and MQAx8. It also features a Class A headphone amplifier circuit and a balanced headphone output capable of delivering an output power of up to 2000mW. It also has Bluetooth functionality, enabling it to support the high-definition codecs aptX, aptX LL, aptx HD and LDAC for reliable, stable wireless transmission. As for connectivity, there's a USB-C input, a coaxial input and a Toslink optical input, while on the output side there's an RCA line output and, of course, two headphone outputs on the front panel: unbalanced 6.35mm jack and balanced 4.4mm jack. An attractive 1.3-inch OLED display and a digital volume control complete the package.
The xDuoo XA-02 supports sampling rates up to PCM 32bit 384kHz and DSD256 via its USB-C input, thanks to its XMOS XU316 + ES9039Q2M chips. It also supports MQAx8. This Hi-Fi device therefore offers the possibility of enjoying high-resolution audio files for the most enjoyable listening experience.
The XA-02 headphone amplifier DAC features a Class A amplifier circuit based on transistors. This enables it to develop power of up to 910mw on its 6.35mm jack headphone output and up to 2000mw on its balanced 4.4mm jack headphone output. This means it can drive a wide range of headphones, from 16 ohm to 600 ohm impedance.
The XA-02 benefits from a balanced architecture that considerably reduces the noise level at its RCA line and headphone outputs. This is reflected in its performance, with a THD+N announced at 0.0005%, an SNR of 121dB and a crosstalk level of 118dB.
The modern XA-02 features Bluetooth functionality, thanks to a Qualcomm QCC5125 chip that supports wireless transmission of high-definition codecs: aptX, aptX LL, aptX HD and LDAC. The result is reliable, stable wireless transmission.
The front panel of the XA-02 features an attractive 1.3” OLED display showing various operating mode information. In addition, a large red backlit potentiometer controls the output volume. The XA-02's volume control is digital. This avoids any problems of imbalance in the event of low volume.
1 | Single-ended jack 6.35mm headphone output |
2 | Balanced jack 4.4mm headphone output |
3 | OLED display |
4 | Menu access button |
5 | Bluetooth pairing button |
6 | Volume control/Source selection/Navigation |
7 | Stereo RCA output |
8 | Coaxial input |
9 | Optical input |
10 | USB-C input |
11 | Update port |
12 | Bluetooth antenna |
13 | IEC power supply/Power switch |
Tachnical characteristics
Product type | DAC / Headphone amplifier |
DAC chip | ES9039Q2M |
USB interface | XMOS XU316 |
Bluetooth chip | QCC5125 |
Inputs | 1x USB-C input 1x Toslink optical input 1x Coaxial input Bluetooth |
Outputs | 1x RCA line output 1x Jack 6.35mm single-ended headphone output 1x Jack 4.4mm balanced headphone output |
Supported sample rates | USB: PCM up to 32bit 384kHz, DSD256, MQAx8 Optical and coaxial: PCM up to 24Bit 192kHz, DSD DoP64 |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
System compatibility | Windows, Linux, Mac OS X, IOS, Android system |
Display | OLED 1.3" |
Recommended headphone impedance | 16-600 ohm |
Jack 6.35mm single-ended headphone output specifications | |
Output power | 910mw @ 32 ohm |
Frequency response | 20Hz-60kHz (±0.5dB) |
Crosstalk | ≥ 71dB |
SNR | 119dB (A-Weighted) |
THD+N | 0.002% |
Jack 4.4mm balanced headphone output specifications | |
Output power | 2000mW @ 32 ohm |
Crosstalk | ≥ 118dB |
SNR | 121dB (A-Weighted) |
THD+N | 0.0004% |
RCA line output specification (AUX) | |
Output level | 2.6Vrms |
THD+N | ≤ 0.0004% |
Power supply | 100-240V AC |
Dimensions | 200 × 175 × 47mm |
Weight | 0.9kg |
Color | Grey |
Package | 1x xDuoo XA-02 1x Mains power cable 1x Bluetooth antenna 1x USB-C cable 1x 3.5mm jack to 6.35mm jack adapter |
Input | USB |
Input | Optical |
Input | SPDIF |
Input | Bluetooth |
Output | RCA |
Output | Jack 4.4mm |
Output | Jack 6.35mm |
DAC / ADC Chip | ES9039Q2M |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Max sampling rate | MQA |
Color | Gray |
Class | Class A / AB |
Networking | No |
Remote Control | No |
