The miniDSP PocketADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs : a Toslink optical output and a coaxial output. Thanks to a DIP switch on one of the front panels, it can convert at several sampling rates up to PCM 24bit 192kHz. Conversion is carried out in such a way as to take advantage of optimal signal digitization for low-noise rendering. Finally, the miniDSP PocketADC is supplied with 12V via DC jack, and also has a secondary power supply output for powering a third-party device.
Product type | ADC converter |
ADC Chip | ES9821Q |
Input | 1x RCA |
Outputs | 1x Optical Toslink 1x Coaxial |
Compatible sample rates | 24bit 48kHz / 96kHz / 192kHz (selection via DIP switch) |
Frequency response | 20Hz-20kHz (±0.1dB) |
Max. input level | 2Vrms |
Input impedance | 100KΩ |
SNR (Signal to Noise Ratio) | 118dB |
THD+N @1kHz | -114dB (0.0002%) |
Crosstalk | -130dB |
Power supply | 12V DC via DC jack (power supply included) |
Power consumption | 2W (idle) |
Dimensions | 13 x 40 x 62mm |
Package | 1x miniDSP PcketADC 1x Power adapter 12V 1.6A 2x DC jack connection cable |
Input | RCA |
Output | Coaxial SPDIF |
Output | Optical Toslink |
DAC / ADC Chip | ES9821Q |
Max sampling rate | 192kHz |
Color | Silver |
