Stereo ADC Board WM8782 I2S 24bit 192kHz
This small stereo ADC module converts an analog signal to digital. The output is thus done in I2S. Equipped with a Cirrus Logic WM8782 chip, the module supports PCM sample rates up to 24bit 192kHz. The clock can be set in Master mode, the module will then use the built-in 22.579M and 24.576M oscillators, or in Slave mode, to use an external clock.
Reference : 14897
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 22-04-2025.
ADC Board
Stereo WM8782 I2S 24bit 192kHz
Module ADC Stéréo WM8782 I2S 24bit 192kHz
This small stereo ADC module converts an analog signal to digital. The output is thus done in I2S. Equipped with a Cirrus Logic WM8782 chip, the module supports PCM sample rates up to 24bit 192kHz. The clock can be set in Master mode, the module will then use the built-in 22.579M and 24.576M oscillators, or in Slave mode, to use an external clock. It is also possible to select an output format from I2S, Left Justified or Right Justified.
Module ADC Stéréo WM8782 I2S 24bit 192kHz Module ADC Stéréo WM8782 I2S 24bit 192kHz Module ADC Stéréo WM8782 I2S 24bit 192kHz Module ADC Stéréo WM8782 I2S 24bit 192kHz Module ADC Stéréo WM8782 I2S 24bit 192kHz
Product typeADC Module
ADC ChipCirrus Logic WM8782
OutputI2S
Supported sampling ratesPCM up to 24bit 192kHz
Clocks22.579M
24.576M
SNR100dB
THD-93dB
Input amplitude of the analog signal voltage1Vrms
Clock modeSwirchable:
Master
Slave
Output formatsI2S
Left Justified
Right Justified
Dimensions50 x 30mm
Supply voltage5V
InputSolder pad
OutputI2S
DAC / ADC ChipWM8782
Max sampling rate192kHz
ColorN/A
2 reviews
Documentation
Arrived in less than a week in a large cardboard box with paper packing, so no damage. However, the device was in a polythene bag with with no electrostatic protection and no documentation. For example, I would like to know the maximum peak-to-peak input put voltage before digital clipping. The web page just says 2 volt rms, which is pretty ambigous.
This review has been posted for Stereo ADC Board WM8782 I2S 24bit 192kHz
Easy Operation and good Soundquality
Everything worked really nice on the first try. It's really handy that it's possible to change the sample rate as i wanted to test something for my own project.
A very very big downside is the absolut slow delivery. I paid 15€ for the delivery from France to Austria and waited almost a week for the parcel.
Therefore I only recommend this store if you have plenty of time and money, or if you live in France.
This small stereo ADC module converts an analog signal to digital. The output is thus done in I2S. Equipped with a Cirrus Logic WM8782 chip, the...
