AIM Ibullet USB Audio Interface for Microphone / Headset Smartphone 4-pole
This USB design interface allows you to use your headphones for Smartphones equipped with microphones and 4-pole Jack connectors on any PC or Mac.
Why will you say?
The advantage of such a product is to make it possible to connect your smartphone microphone to your PC / Mac.
So your headset sold with your smartphone can also be used as a headset for your PC or Mac.
It also improves the signal-to-noise ratio at input and output compared to the original components of these devices.
Characteristics :
- Patented technology and design
- Converter: Cmedia HS100
- Connector: 3.5 mm 4-pin plug
- Compliance: USB 2.0 full speed, Plug & Play, compatible with USB 1.0
- Headphone Output: 16-bit, 44 KHz / 48 KHz, SNR 93dB
- Input Micro 16-bit, 44 KHz / 48 KHz, SNR 83dB
- LED: blue indicating the status
- Dimensions: 39.6 x 22.1 x 12.3mm
- Weight: 6g
- Interface: USB type A male
- PC and MAC compatible: Plug & Play
- PS: Not suitable for Nokia and Sony phones
"> Only available
in white
P>
