Audio-GD DAC NFB 1.32 - 32Bit / 192khz COAX / OPT / USB Sabre ES9018
Reference : 7004
649,00 €tax incl.
540,83 € tax excl.
The NFB-1.32 family of the non-feeedback family integrates an ES9018 Sabre supporting up to 32 bits 192khz and this on all inputs thanks to the new asynchronous interface USB32 of the manufacturer (32bit / 384Khz).
NFB is the acronym for Non-feedback; technology used by Audio-Gd so as not to "color" the sound at the level of the electronics of the output stage giving you a sound of a very professional neutrality.
The 100% symmetrical and discreet design of this converter is backed by a 5 class A power supply.
24k Gold Plated RCAs and Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Characteristics :
  • USB interface: USB 32 (VIA VT 1731)
  • SPDIF Receiver: WM8805
  • DAC: SABRE ES9018
Signal / noise ratio
> 120db
Output Impedance
Output Level
2.5V (RCA)
5V (XLR)
1.2 + 1.2MA (ACSS)
Input sensitivity
0.5 Vp-p (75 Ohms, Coaxial)
19 dBm (Optical)
USB1.1, USB2.0 (Full Speed, Class2)
Supported Systems
Windows: 44.1kHz to 192kHz
OSX: 44.1kHz to 384KHz
Linux: 44.1kHz to 192kHz
Supported sampling rates
size = "2"> USB model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Optical mod
el: 44.1kHz, 48kHz, 88.2kHz, 96kHz (176.4KHz and 192KHz available if the source support)
DSD 64/128
DXD
Frequency Response
20Hz - 20KHz
Consumption220-240V AC 50/60 Hz 17W
Dimensions240 X 360 X 80 mm
Weight
5KG
AccessoriesAC power cord X1
https://www.audiophonics.fr/images2/7004/7004_AUDIOGD_NFB1.32_1.jpg
https://www.audiophonics.fr/images2/7004/7004_AUDIOGD_NFB1.32_2.jpg
https://www.audiophonics.fr/images2/7004/7004_AUDIOGD_NFB1.32_3.jpg
OutputACSS
DAC / ADC ChipES9018
Max sampling rate192kHz
