Audio-GD NFB-11 (2014) ES9018 DAC / PREAMP DSD / DXD 32Bit / 384khz
Reference : 6859
315,00 €tax incl.
262,50 € tax excl.
New version of NFB-11.32 with DSD / DXD support.
True Swiss Audiophile knife, it combines the functions of DAC, headphone amplifier and preamplifier.
NFB is the acronym for Non-feedback; technology used by Audio-Gd so as not to "color" the sound at the level of the electronics of the output stage giving you a sound of a very professional neutrality.
The integrated ES9018 Saber allows you to manage 32bit 192Khz sources both via USB and SPDIF.
The 100% discreet design of this amplifier (no PDO) is backed by a high power power supply.
The Alps 27, 24k Gold Plated RCAs and Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
The Toshiba and Hitachi transistors were manually paired.
Features:/ Strong>
  • USB interface: USB 32 (VIA VT 1731)
  • DAC: SABER ES9018
  • DSD (64 and 128) / DXD
Signal / noise ratio
118dB
Output Level
Headphone output: 10V RMS
Variable output: 5V Max
Fixed output: 2.25V RMS
Output Power (Headphones).
3500mW / 25 ohm
1800mW / 50 ohm
900mW / 100 ohm
300mW / 300 ohm
150mW / 600 ohm
Output impedance
2 ohm / Headphone output
2 ohm / DAC output
Operating Systems
Windows: 44.1kHz to 192kHz music files
OSX: 44.1kHz to 384KHz music files
Linux: 44.1kHz to 192kHz music files
Sampling rate
USB model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz
Coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Optical model: 44.1kHz, 48kHz, 88.2kHz, 96k
DSD 64/128
DXD
Input sensitivity
0.5 Vp-p (75 Ohms, Coaxial)
19 dBm (Optical)
USB1.1 / 2.0 (Full Speed)
Frequency Response
20Hz - 20KHz (-0.2db)
3Hz- 350KHz (analog circuit)
Consumption
12W
Weight
2KG
Accessories
AC power cord X1
USBcable X1
https://www.audiophonics.fr/images2/6859/6859_audio-gd_nfb-11-2014_ampli_dac_1.jpg
https://www.audiophonics.fr/images2/6859/6859_audio-gd_nfb-11-2014_ampli_dac_2.jpg
https://www.audiophonics.fr/images2/6859/6859_audio-gd_nfb-11-2014_ampli_dac_3.jpg
https://www.audiophonics.fr/images2/6859/6859_audio-gd_nfb-11-2014_ampli_dac_4.jpg
Manufacturer:
2 reviews
Intercalé entre mon lecteur NAD C515 (utilisé uniquement en drive) et mon ampli C326BEE de la même marque qui drive des Totem Mite, cette Little Magic Black Box à fait progresser mon installation de manière spectaculaire ! Pas dans le démonstratif, mais en terme de naturel, de détails, de véracité des timbres et de dynamique (qui manquait à mon lecteur).
Merci Audiophonics pour le conseil quand je cherchais un DAC pour "pim'per" mon lecteur CD.
This review has been posted for Audio-GD NFB-11 (2014) ES9018 DAC / PREAMP DSD / DXD 32Bit / 384khz
Je rédige cette note après une toute première écoute en comparaison avec mon V-DAC + VLink192, pourtant pas déméritant. L'interface USB VLink192 est conservée avec le AUDIO-GD 11.32. Or, l'écoute du 11.32 m'a scotché ! Je n'en reviens pas d'un tel écard entre ces 2 DAC.
L'image est grandiose, les timbres et les voix sont d'un naturel inouï ! Attention au choix des cables, c'est extrêmement important avec ce DAC car les résultats d'écoutes pourraient être faussés avec un cable mal adapté (c'est la 1ere fois que mon Wireworld Sarlight silver numérique est mis en défaut avec ce DAC. Il apporte un brillant peu naturel. Mais ce n'est pas le DAC ! remplacé par un Van den Hull "the First Ultimate" tout carbone, le résultat est incroyable !!). A ce tarif, ce DAC est une bombe ... musicale :)
Merci à AUDIOPHONICS, livraison hyper rapide, relationel impeccable; je suis ravis !! Achat de ce DAC très fortement conseillé !
