AUDIO-GD NFB-15 (2014) DAC / Preamp / Amplifier 24bit / 192kHz 2x WM8741 TCXO
4.3 / 5
Reference : 8926
339,00 €tax incl.
282,50 € tax excl.
The NFB-15 2014 is an evolution of the Best Seller NFB 15.32 benefiting from the brand new USB 32 interface supporting high sampling rates.
True Swiss Audiophile knife, it combines the functions of DAC, headphone amplifier and preamplifier.
NFB is the acronym for Non-feedback; technology used by Audio-Gd so as not to "color" the sound at the level of the electronics of the output stage giving you a sound of a very professional neutrality.
The integrated VT 1371 (USB32) allows you to manage 24bit 192kHz sources both via USB and SPDIF coaxial.
The 100% discreet design of this amplifier (no PDO) is backed by a high power power supply.
The ALPS RK27, 24k Gold Plated RCAs and Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
The Toshiba and Hitachi transistors were manually paired.
Included Options:
  • 35W Transformer
  • Clocks TCXO x2 (USB 32 & DAC)
Characteristics :
  • USB interface: USB 32 (VIA VT 1731)
  • DAC: 2 x WM8741
  • Inputs: USB, Coaxial, Optical
  • Outputs: Headphones, RCA Analog Fixed, RCA Analog Variable (Preamp Function)
  • TCXO option 100MHz included
"bgcolor =" # C0C0C0 "width =" 299 ">Signal / noise ratio
118dB
Output Level
Headphone output: 10V RMS
Variable output: 5V Max
Fixed output: 2.25V RMS
Output Power (Headphones).
3500mW / 25 ohm
1800mW / 50 ohm
900mW / 100 ohm
300mW / 300 ohm
150mW / 600 ohm
Output impedance
2 ohm / Headphone output
2 ohm / DAC output
Sample rate
Coaxial: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Optical: 44.1kHz, 48kHz, 88.2kHz, 96kHz
Input sensitivity
0.5 Vp-p (75 Ohms, Coaxial)
19 dBm (Optical)
USB1.1 / 2.0 (Full Speed)
Frequency Response
20Hz - 20KHz (-0.2db)
Consumption
11W
Weight
2KG
Accessories
AC power cord X1
USB cable X1
Manufacturer:
Qobuz
Test in English (Click Here)
[Img-14661-left-thickbox_default]
[Img-13667-left-thickbox_default]
https://www.audiophonics.fr/images2/7193/7193_audio-gd_15-322014_1.jpg
https://www.audiophonics.fr/images2/7193/7193_audio-gd_15-322014_2.jpg
3 reviews
La boite à musique de Pandore
Voila bien une petite prouesse de la part du réputé Audio-Gd.
Ce petit NFB-15 fait vraiment des merveilles et arrive a surpasser du matos haut de gamme qui vaut plusieurs fois son prix.
Après avoir testé pas de nombreux DAC/Ampli casque (combo ou séparés) allant de 700 à 1700€ c'est finalement sur celui-ci que je me suis arrêté.
A propos de la musicalité :
- Pour le haut du spectre, c'est clair et délié. Très très bien reproduit. Ayant un casque qui a tendance à tirer vers le haut, l'écoute n'est jamais fatigante. Ils ne sont pas en retrait, ni "doux". Ils sont simplement propres. C'est clair et net. On sent qu'ils sont sous controle, ce qui est rare dans cette tranche de prix.
- Les médiums. Ils sont beaux aussi. Un poil plus en avant aurait été parfait, je pense. Mais ma préférence pour cette partie du spectre ne me rend pas forcément objectif ;) M'enfin c'est tout de même très bon.
- Très bien également pour le bas du spectre. Les basses sont sèches et non boomy (j'ai horreur de cela). Ça à du punch mais ca reste très équilibré. Les purs basseux ne seront pas satisfait mais les personnes en quête d'un amli/DAC Hi-Fi le seront a coup sur. Un détail impressionnant : les basses sont bien détaillés. En écoutant mon album favoris des Daft Punk, j'arrive à dicerner toutes les notes de la batterie... tellement appréciable.
- Les voix. C'est certainement la que la plus grande magie du double WM8741 fait son, effet. La reproduction des voix est impressionnante. D'une clareté sans reproche. Elles sont légèrement mises en avant. C'est doux et délié. C'est ce qui m'a le plus conquis avec cet Audio-Gd. Quand je choisis un morceau avec une belle voix, c'est un pur plaisir rien qu'en cliquant sur play : je sais d'avance que je vais prendre mon pied. Le "voile" dont on parle tant est ici bien lévé. Et cela sans perturber la restitution du reste du spectre.
D'une manière générale l'ensemble est très propre, précis et détaillé.
N'ayant pas essayé les autres DAC aux puces Sabre de la marque, la comparaison est difficile. L'avantage ici est que l'on profite de quelque chose d'un poil arrondi au niveau restitution. On ne tombe pas dans quelque chose d'analytique. Du coup tout en restant fidèle et équilibré, on arrive a avoir un résultat plaisant à écoute et pas fatiguant. Sans être dans le coté 200% neutre des puces Sabre, qui perd peut être de son intérêt pour de l'écoute Hi-Fi.
Bref, vous l'aurez compris je suis complètement conquis par ce bijou. Du coup, je me demande comment les autres fabriquants arrivent a justifier des tarifs exorbitant quand cet audi-gd arrive a faire bien mieux.
Assurément une prouesse de musicalité de la part d'un fabricant qui n'a plus a prouvé sa réputation dans le domaine audiophile.
Du matériel de très haute volée pour un prix, quant a lui, très doux.
Well done audio-gd ! Encore un coup de maître.
Romain.
This review has been posted for AUDIO-GD NFB-15 (2014) DAC / Preamp / Amplifier 24bit / 192kHz 2x WM8741 TCXO
Épatant !
Dans le même esprit que le commentaire précédent, j'ai acheté pour me faire une idée sur cette marque qui fait du "bruit". Et bien, pas déçu d'autant pour un modèle d'entrée de gamme ! Beaux timbres, finesse, délié... manque juste d'un peu de dynamique en comparaison de mes alimentations surdimensionnées Cairn mais une fois encore, on se situe en entrée de gamme, donc... Par contre, extrêmement polyvalent, que ce soit sur mon système fixe all Cairn (class A) avec un RSPI2 sous Runeaudio et avec une alim. régulée 5V qu'on trouve sur le site ; ou en autonomie même config mais en jouant la carte du pré. et de l'ampli du Dac avec un Sennheiser HD 560 Ovation II rescucité pour l'occasion. Plus que très chaudement recommandé et ça donne même envie de monter en gamme illico :)
Un son fabuleux
UN des meilleurs rapport qualité prix selon beaucoup de sites et de forums audiophiles, et c'est vrai!
look basic, solide et simple d'emploi et surtout un son clair, délié, précis.
