AUDIO-GD NFB-7 (2014) DAC ES9018 ACSS / XLR / RCA DSD / DXD 32bit / 192kHz
Reference : 6797
1 490,00 €tax incl.
1 241,67 € tax excl.
Including 1,00 € for green tax
This high-end converter takes the qualities of the NFB-7 by using a new design of the analog output stage giving it a gain in sound quality and greater neutrality
Nothing in this device was left to chance, the use of the ES9018 allows it a native management of 32bit / 192Khz streams on all digital inputs.
This one thanks to its extended connectivity is compatible with all the amplifiers of the market.
NFB is the acronym for Non-feedback, a technology used by Audio-Gd so that it does not "color" the sound at the level of the output stage electronics, giving you a sound of professional neutrality.
The 100% discreet design of this converter is backed by several high power class A power supplies (15 groups).
The 24k Gold Plated RCAs and the Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Attention Saber 32 ES9018 is a demanding component, some low-end coaxial or Toslink cable and a low output level of the source will not allow it to properly handle the 192khz.
Features:/ Strong>
  • USB interface: USB 32 (VIA VT 1731)
  • DAC: SABER ES9018
  • DSD (64 and 128) / DXD
  • OCC wiring and TCXO clock included
options
OCC Wiring + TCXOs Clock
Ratio RCA Signal / Noise
> 120db
Output Impedance
10 ohm
Output Level
2.5V (RCA)
5V (XLR)
2 + 2 mA (ACSS)
-Sensitivitythe entrance
0.5 Vp-p (75 Ohms, Coaxial)
19 dBm (Optical)
USB1.1 / 2.0 (High Speed ​​/ Full Speed)
System Support (USB)
Windows: 44.1kHz to 192kHz music files
OSX: 44.1kHz to 384KHz music files
Linux: 44.1kHz to 192kHz music files
Supported sampling rates
USB model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz
Coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Optical model: 44.1kHz, 48kHz, 88.2kHz, 96kHz
DSD 64/128
DXD
Frequency Response
20Hz - 20KHz
Dimensions430 mm X 430 mm X 85 mmConsumption38WWeight
15KG
Accessories
Cordon sector
USB cable
Manufacturer:
https://www.audiophonics.fr/images2/6797/6797_AUDIOGDNFB7.1_1.jpg
https://www.audiophonics.fr/images2/6797/6797_AUDIOGDNFB7.1_2.jpg
https://www.audiophonics.fr/images2/6797/6797_AUDIOGDNFB7.1_3.jpg
InputXLR
InputRJ45
InputBNC
OutputACSS
DAC / ADC ChipES9018
Max sampling rate192kHz
2 reviews
J'ai commandé ce convertisseur pour remplacer mon ancien Audiomat tango2 il y a quelque mois.
J'ai lu pas de mal de forum américain et je me suis lancé, tant pis pour l'écoute.
Que dire, mis à part que je pense que le rapport qualité/prix est assez ... incroyable.
J'ai vraiment écouté beaucoup de système et il est clair que ce DAC est impressionnant.
Spectre:
Il n'est pas agressif (ce dont j'avais peur) mais d'un discernement et d'une précision chirurgicale quelques soient les enregistrements (d'ailleurs certains sont passés à la trappe).
Les graves sont profonds, les médium sont très plaisants, les aigus sont excellent. J'ai gagné sur tout le spectre. La dynamique est incroyable et les détails perçus sont bluffants.
Les voix, les instruments tout y est.
Je l'ai testé avec différentes systèmes, amplis, enceintes, câbles et chaque fois il a su s'adapter, le son changeant, évoluant ... il est clair que ce n'est pas le maillon faible.
J'ai un système assez évolué avec un ampli à tube (Audiomat) et un autre à transistor (ONIX HDG), différentes enceintes DIY assez HDG aussi.
Je n'ai pour l'instant pas réussi à le prendre en défaut.
J'ai envoyé plusieurs e-mail à audiophonics qui a toujours était disponible et idem pour Kingwa (M. AUdio-GD). merci à eux.
This review has been posted for AUDIO-GD NFB-7 (2014) DAC ES9018 ACSS / XLR / RCA DSD / DXD 32bit / 192kHz
L’audio GD NFB 7.1 est de présentation assez sobre et assez bien finit, on peut lui reprocher le bruit épouvantable des boutons de sélections, car l’appareil étant entièrement en aluminium, ceux-ci font un bruit de ressort métallique qui est immanquablement amplifié par le boitier, seul solution c’est de placer un lecteur cd assez lourd sur le dessus, cela atténueras le phénomène ou attendre la fin de la garantie de l’appareil et y placer çà et là à l’intérieur sur les parois, quelque morceau de plaque bitumineuse adhésive qui isoleront et amortirons tous bruit parasite !
Bon ceci dit une fois sélectionné, ont utilise plus que le bouton "power" par la suite!
J’ai installé se dac sur un de mes systèmes Hifi, qui est composé d’un lecteur cd Marantz SA11S2, d’un ampli à lampe Prima luna prologue Two et d’une paire de Dynaudio DM2/10, tout le câblage étant en Sound Quintessence-audio, La SCALA (Hp), Vesta (secteur), Titans (modulation analogique) et PHAROS en coaxial numérique !
J’ai commencé l’écoute avec le câble optique fournit par audio GD, très vite je me suis demandé si quelque chose ne fonctionnais pas ou si en fait mon convertisseur du Marantz n’étais pas meilleurs, car aucune différence n’étais audible, même après une heure de chauffe et sur des disques archi connus !
J’ai retiré le câble optique pour le PHAROS coaxiale numérique et là c’est carrément la claque !!!
Le grave gagne en fermeté et en définition, les médium sont enfin au même niveau que les autres registres, alors qu’avant il était en léger retrait, avec une acidité vers le haut, la ont gagne en présence, en douceur, avec des timbres magnifiques, l’aigu est tout simplement bluffant, ont entends très distinctement le jeux et les nuances sur les cymbales, pas d’effet numérique très mécanique et dur sur cette partie très délicate à reproduire, mais le clou du spectacle, c’est la scène sonore qui s’élargie, on distingue le positionnement exacte des musiciens, on gagne aussi en profondeur, les fin de réverbération sont très distinct, l’écoute deviens holographique !
En résumé, car il y aurait encore beaucoup à dire, ce DAC mal-grès quelque petites amélioration à apporter sur la finition est remarquable de justesse, de beauté des timbres, d’équilibre, de spatialisation et il procure de l'émotion, il vaut largement un Weiss 202 coûtant 4 fois plus chère et équipé de la même puce ESS9018 !
Par contre, ne négligé pas la qualité du câblage, car une petite économie et un mauvais choix suffit à ruiner tout un investissement matériel et vous faire repartir dans une quête du graal sans fin !
