AUDIOPHONICS U-SABRE USB DAC 24Bit/96kHz SA9023 / ES9023 OTG V2.2E TCXO Edition
4.8 / 5
Reference : 11056
44,90 €tax incl.
37,42 € tax excl.
This product has been replaced by the new version, the AUDIOPHONICS U-SABRE PRO DAC USB 32Bit/384kHz SA9227 / ES9018K2M.
Audiophonics U-Sabre
USB DAC 24bit/96kHz SA9023 / ES9023 V2.2E TCXO Edition with Optical Output
Audiophonics U-Sabre ES9023 TCXO
A DAC with an incredible sound.
The DAC Audiophonics U-SABRE TCXO USB V2.2E evolves with an update of the PCB and the addition of a digital output in mini format TOSLINK 24bit 96Khz. The benefits of this nomadic DAC are many.
The quality of the components is of the very first order with capacitors from Vima, Rodenstein. So here is a DAC format of pocket with the great sound of Hifi devices of living room.
High precision TCXO USB DAC
The analog output has only two high quality film capacitors on its path. The auditory result is immediately tangible with greater freedom in the acute medium and a perfectly cut out grave register. A USB DAC with high-end features in a compact format
This new version features a mini Toslink 24/96 digital output paired with the 3.5mm analog output.
Compact and musical
Un DAC USB Audio Plug-and-Play Audiophile
The DAC Audiophonics U-Sabre ES9023 USB powered on any laptop or computer has a 6V or 9V external power port for problems with USB ports with low amperage.
Audiophonics TCXO
The full-size 27Mhz TCXO Clock implemented in the Audiophonics U-SABRE TCXO provides the feeling and more differentiation in harmonics. Therefore this DAC is absolutely not tiring to listen thanks to a jitter (0.5PPM) reduced.
ES9023P
This high-definition nomadic DAC, equipped with the famous ES9023 SABRE 24bit 96Khz, integrates the Hyperstream technology to compensate for the usual defects of the classic Delta Sigma DACs. The result is immediately tangible, with a feeling, a sound precision above the competing technologies Delta Sigma.
Linear technology LDO LT1763
This product can work like the old generations ie directly in USB, without additional power supply optimally thanks to its original low noise regulator Linear technology LDO LT1763.
Test du Audiophonics U-Sabre ES9023 TCXO par Qobuz
" C'est une restitution sonore assez chatoyante, assez typique des puces de conversion numérique analogique de la marque ESS, et peut-être même plus prononcée qu'habituellement, que procure le DAC U-Sabre ES9023 TCXO. Peut-être pas ce qu'il y a de plus naturel, mais agréable et lumineux. "
Test Qobuz
CompatibilityPlug & Play on Windows, Linux et OS X / OTG
USB ModeAdaptative
DACAsynchrone Sabre ES9023
Direct Out(Minimum Analog Output Scheme)
Power SupplyNo external power required - Optionnal external power supply on DC Jack 2.5x2.1mm 6V-9V DC
ClockHigh Precision TCXO (0.5ppm)
l'ASIO SupportYes (driver available in the download section of this page)
PackageU-SABRE TCXO
Input
USB InterfaceSA9023 (SAVIAUDIO) : 16/24 bit and 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz
I2S-
USB(We recommend the use of qualitative cable and length less than 1.5m)
Output
Jack 3.5mmLine (1.7V rms)
RCA Stereo1.7V rms
Optical mini toslinkMini Toslink format 24bit / 96kHz
Audiophonics ES9023 TCXO
Recommended by the press
 Clubic
Micougnou
OutputOptical Toslink
OutputJack 3.5mm
Max sampling rate96kHz
45 reviews
Parfait !
Tout a déjà été dit, la qualité d'écoute vaut bien ce petit investissement (avec des câbles USB et RCA de qualité). J'ajoute que l'amélioration de la clarté notamment sur la parole permet une écoute plus attentive des langues étrangères.
En bonus : Ce DAC est compatible avec la console de jeu PS5.
This review has been posted for AUDIOPHONICS U-SABRE USB DAC 24Bit/96kHz SA9023 / ES9023 OTG V2.2E TCXO Edition
Excellent, dommage qu'il ne soit plus produit
Cet excellent petit DAC à prix très abordable a malheureusement été remplacé par une version 'Pro' - et meilleure probablement, mais 50% plus cher.
Je comprends les impératifs techniques et financiers mais il est dommage que les 2 modèles ne peuvent pas coexister: pas toujours besoin du top du top et les clients potentiels pour ce DAC vont devoir se tourner vers une autre marque plutôt que la version 'Pro'
Excellent rapport qualité/prix
Associé à Daphile sur un "vieux" Netbook Samsung NC10, voilà qui me permet de disposer d'une solution portable/nomade de musique dématérialisée suffisante pour mon usage sur mes différentes chaine hifi 'vintage' et à un prix doux.
Seul bémol : prévoir un câble USB court de qualité, non fourni. Les câbles d'imprimante sont inefficaces.
Dac U-sabre
Fonctionne correctement.Par contre, impossible de faire fonctionner ce DAC avec les pilotes ASIO, tout est haché, j'ai du laisser les pilotes windows.
Πάρα πολύ καλό.
Το έχω συνδέσει σε παθητικό προενισχυτή με ενεργά ηχεία.
Του έχω βάλει γραμμικό τροφοδοτικό 7,5V 1Α.
Με διακοπτικό τροφοδοτικό 9V 2,77Α έπαιξε χειρότερα...
Επίσης οι δύο πυκνωτές 390pF της Evox αλλάχθηκαν με Wima FKP και έπαιξε ακόμα καλύτερα.
Έπαιξε καλύτερα από dac των 319,00 euro...
Οπότε είναι ένα δώρο σ' αυτή την τιμή.-
